I'm trying to build RGB led color picker from ladyada.net tutorials. http://www.ladyada.net/make/eshield/examples.html
I build ethernet shield, installed on my Arduino Duemilanove with ATMEGA328 and then load the sketch from ladyada web site. http://www.ladyada.net/make/eshield/LEDcolorpicker.pde
This code dosent's work for me, until I break line into two separate and re-merge at runtime. I need to remove some piece of code to make it works.
After burning 3 times this sketch on my Arduino, it seems not to responde anymore. On extensive log I see:
     avrdude: Version 5.4-arduino, compiled on Oct  9 2007 at 11:20:31
     Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
     System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
     User configuration file is "/Users/emaaaa/.avrduderc"
     User configuration file does not exist or is not a regular file, skipping
     Using Port            : /dev/tty.usbserial-A9007MIy
     Using Programmer      : stk500v1
     Overriding Baud Rate  : 115200
     avrdude: Send: 0 [30]   [20]
     avrdude: ser_recv(): programmer is not responding
     avrdude: stk500_recv(): programmer is not responding
     avrdude: Send: Q [51]   [20]
Anyone have some ideas ? I tryed on 2 different arduino 2009, same results
Thanks.
The const char javascript[] PROGMEM = "..." is a >5,000 character string. It's possible that the Arduino IDE doesn't support line lengths of this size, you can break it up using the continuation character \ at the end of your line:
const char javascript[] PROGMEM = "<script type=\"text/javascript\">function" \
" getScrollY(){var scrOfX = 0,scrOfY=0;if(typeof(window.pageYOffset)=='number')" \
"{scrOfY=window.pageYOffset;scrOfX=window.pageXOffset;}else if(document.body&&" \
[Many more lines]
"setCCbldSty2('colorpicker201','ds','block');" \
"document.getElementById('colorpicker201').innerHTML=mid;}</script>";
Note that you can't have // comments at the end of these lines.
If this is what you meant by "broke into 2 parts" you should be fine. Otherwise, I think your reassembly at runtime is suspicious.
  • \$\begingroup\$ I will try to upload this sketch as soon I restore my Arudino. I'm not able to upload nothing to IT after i upload the ledpitcher sketch. It continuosly blink the mini led and report error top of this page message \$\endgroup\$
    – user3562
    Mar 24, 2011 at 21:48
I know after awhile on my arduino that i had to start pressing the reset button before sending the sketch, this may help. Next try just using a simple LED blinky sketch(can be found in the examples on the IDE) If it works your arduino is fine.
as for the other sketch I don't understand what you mean by this
This code [does not] work for me, until I break line into two separate and re-merge at runtime. I need to remove some piece of code to make it works.
can you explain that a little better?
  • \$\begingroup\$ Thank jsolarski ;) I press the reset butotn on arudino but nothing change, even if I try to upload blinking led sketch nothing happen. Some strange behaviour on Arudino is the mini-led soldierd onboard is blinking continuosly a high frequncy. <br> In led picker sketch at line 25 there's a "const char javascript[] PROGMEM = ", If i leave this as is Arudino IDE dosen't allow me to build. If i broke into 2 parts it run. \$\endgroup\$
    – user3562
    Mar 24, 2011 at 13:56
