I originally asked the this question on Stack Overflow. I think here would have been a better audience.
I'm trying to program a PIC12C508A to do a simple LED learning circuit. I've read some examples, the Microchip Datasheet, pic12c508a.h and pic12c508a.inc. I've tried to set the TRIS register using a C program and an ASM program but it does not take. Using MPLAB X, the XC8 compiler, and the built in simulator to check the SFR registers I can see that the TRIS is not updating even when the WREG holds the correct values. If anyone has experience with this please check out my code and see if I am doing something wrong.
#include <xc.h>
// -- CONFIG
#pragma config MCLRE = ON // RA5/MCLR/VPP Pin Function Select bit (RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD)
#pragma config WDT = OFF // Turn Watchdog Timer Off.
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
#pragma config OSC = IntRC // Internal RC Oscillator
// -- Internal Frequency
#define _XTAL_FREQ 400000
int main()
OPTION = 0b11011111; // Added this from feedback on Stack Overflow
//--0----- Clear T0CS per PIC12C508A datasheet on using GP2 as output
TRIS = 0b111010; // 0x3A
//---0-0 Set GP0 and GP2 as outputs
GPIO = 0b000100; // 0x04
//---1-0 Set GP2 as HIGH and GP0 as LOW
for(int countdown = 10; countdown > 0; --countdown) {
__delay_ms(60000); // Delay 1 minute.
GPIO = 0b000001; // 0x01
//---0-1 Set GP2 as LOW and GP0 as HIGH
while(1)
NOP();
I also tried it in assembly which is pretty much identical to the Gooligum tutorials for baseline PIC models. (Update: I have not tried to set the OPTION register in ASM yet.)
list p=12c508a
#include <p12c508a.inc>
__CONFIG _MCLRE_ON & _CP_OFF & _WDT_OFF & _IntRC_OSC
RCCAL CODE 0x0FF ; Processor Reset Vector
res 1 ; Hold internal RC cal value, as a movlw k
RESET CODE 0x000 ; RESET VECTOR
movwf OSCCAL ; Factory Calibration
start
movlw b'111010' ; Configure GP0/GP2 as outputs
tris GPIO ;
movlw b'000100' ; Set GP2 HIGH - GREEN LED
movwf GPIO
goto $ ; loop forever
END
This all seems pretty straight forward but when I use breakpoints and examine the SFR registers in the simulator I can see that the GPIO and TRIS registers are never changed even though the WREG will hold the correct values. I've examined the ASM output that the XC8 compiler generates and it is almost identical to the ASM I wrote when it comes to setting the registers.
I've also tried using HEX values and straight integer values and the results are the same.
