I am trying to investigate the RST5.5, RST6.5, and RST7.5 interrupts on the 8085 microprocessor.
I want to find information about the to the type of interrupting signal used and the built in hardwired priority scheme,but finding resources explained in a plain and simple way is next to impossible...even the Intel documents are very hard to understand!!
    \$\begingroup\$ Why are you using such an obsolete device? \$\endgroup\$ – Leon Heller Mar 27 '11 at 14:58
  • \$\begingroup\$ I read that it was a good way to begin learning about microprocessors. \$\endgroup\$ – user3617 Mar 27 '11 at 15:11
    \$\begingroup\$ No one uses it any more. There are lots of newer devices that are in common use, and are much easier to use, such as PICs and AVRs. \$\endgroup\$ – Leon Heller Mar 27 '11 at 15:21
  • \$\begingroup\$ Isn't it the basis for most modern processors though? \$\endgroup\$ – user3617 Mar 27 '11 at 17:43
If you want to learn about interrupt-driven programming by studying old processors, the Z-80 might be a better bet... one of its features was a better interrupt system.
I learned a lot of hard-won lessons by writing an interrupt-driven serial I/O handler for the thing!
But if you're really wanting to learn about interrupts, it might be better to use a CPU where you have easy access to a system for development and test.
