I have a current transformer with following specification:
- LV Current Transformer
- Type : RLC-50
- PT : 1
- Ratio : 400/5 A
- Class : 1.
I want to know the meaning of PT and RLC-50?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have a current transformer with following specification:
- Type : RLC-50
- PT : 1
- Ratio : 400/5 A
- Class : 1.
RLC-50 is the series number. You can use that to look up the datasheet, especially if you know the manufacturer name, since more than one maker uses that series name (probably copied from ABB). The 50 refers to the inside diameter of the hole in the CT (~50mm).
PT is primary turns for the rated 400:5 ratio. One turn means that you just run the high-current wire through the hole and don't loop it more than once.
