I'm working on a simple project. I want to send a string. the string is "Rohalamin". the second board after recieve the string should turn on the LED.
the program for first board is (the MCU for this board is STM32F030F4):
/* Includes ------------------------------------------------------------------*/
#include "stm32f0xx_hal.h"
/* Private variables ---------------------------------------------------------*/
SPI_HandleTypeDef hspi1;
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_SPI1_Init(void);
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* System interrupt init*/
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_SPI1_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* USER CODE BEGIN 3 */
  /* Infinite loop */
  while (1)
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6;
  RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
  __SYSCFG_CLK_ENABLE();
/* SPI1 init function */
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_MASTER;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_HARD_OUTPUT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_32;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLED;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLED;
  HAL_SPI_Init(&hspi1);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __GPIOF_CLK_ENABLE();
  __GPIOA_CLK_ENABLE();
  /*Configure GPIO pin : PA0 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /* EXTI interrupt init*/
  HAL_NVIC_SetPriority(EXTI0_1_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(EXTI0_1_IRQn);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif
the stm32f0xx_it.h file for handling interupt:
#include "stm32f0xx.h"
#include "stm32f0xx_it.h"
/* External variables --------------------------------------------------------*/
extern SPI_HandleTypeDef hspi1;
uint8_t aTxBuffer[] = "Rohalamin";
/*            Cortex-M4 Processor Interruption and Exception Handlers         */
* @brief This function handles System tick timer.
void SysTick_Handler(void)
  HAL_IncTick();
  HAL_SYSTICK_IRQHandler();
* @brief This function handles SPI1 global interrupt.
void SPI1_IRQHandler(void)
  HAL_NVIC_ClearPendingIRQ(SPI1_IRQn);
  HAL_SPI_IRQHandler(&hspi1);
* @brief This function handles EXTI Line 0 and Line 1 interrupts.
void EXTI0_1_IRQHandler(void)
  HAL_NVIC_ClearPendingIRQ(EXTI0_1_IRQn);
  HAL_SPI_Transmit_IT( &hspi1 , (uint8_t*)aTxBuffer , 10 );
  HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_0);
And now the program for second board (the MCU for this board is STM32F103RET6):
#include "stm32f10x.h"
#include <string.h>
/* Private macro -------------------------------------------------------------*/
#define RxBufferSize   0x20
char RxBuffer[RxBufferSize];
uint8_t NbrOfDataToRead = RxBufferSize;
uint16_t RxCounter = 0;
char aTxBuffer[0x20] = "Rohalamin";
/* Private functions ---------------------------------------------------------*/
RCC_ClocksTypeDef RCC_ClockFreq;
ErrorStatus HSEStartUpStatus;
GPIO_InitTypeDef GPIO_InitStructure;
SPI_InitTypeDef SPI_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
void SetSysClockTo72(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void _SPI1(void);
* Function Name  : main
* Description    : Main Programme
* Input          : None
* Output         : None
* Return         : None
* Attention      : None
int main(void)
    SetSysClockTo72();
    GPIO_Configuration();
    _SPI1();
    NVIC_Configuration();
    SPI_I2S_ITConfig( SPI1 , SPI_I2S_IT_RXNE , ENABLE );
    SPI_Cmd( SPI1 , ENABLE );
    /* Infinite loop */
    while (1)
            if( strcmp(RxBuffer , aTxBuffer) == 0 )
                GPIOB->ODR ^= GPIO_Pin_0;
  * @brief  Sets System clock frequency to 72MHz and configure HCLK, PCLK2
  *         and PCLK1 prescalers.
  * @param  None
  * @retval None
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration -----------------------------*/
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 6 = 48 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_6);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
* Function Name  : GPIO_Configuration
* Description    : Configure GPIO Pin
* Input          : None
* Output         : None
* Return         : None
* Attention      : None
  RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB , ENABLE);
 *  LED1 -> PB0
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init( GPIOB , &GPIO_InitStructure );
 *  NSS -> PA4
        SCK -> PA5
        MISO -> PA6
        MOSI -> PA7
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA , ENABLE );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init( GPIOA , &GPIO_InitStructure );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
void _SPI1(void)
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_SPI1 , ENABLE );
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
    SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
    SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
    SPI_InitStructure.SPI_CRCPolynomial = 7;
    SPI_Init( SPI1 , &SPI_InitStructure );
  /* Enable and configure SPI1 global IRQ channel */
  NVIC_InitStructure.NVIC_IRQChannel = SPI1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
    /* Enable and configure RCC global IRQ channel */
  NVIC_InitStructure.NVIC_IRQChannel = RCC_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
/*            STM32F10x Peripherals Interrupt Handlers                        */
  * @brief  This function handles SPI1 global interrupt request.
  * @param  None
  * @retval None
  if(SPI_I2S_GetITStatus( SPI1 , SPI_I2S_FLAG_RXNE ) != RESET)
    /* Read one byte from the receive data register */
    RxBuffer[RxCounter++] = (SPI_I2S_ReceiveData(SPI1) & 0x7F);
    if(RxCounter == NbrOfDataToRead)
      /* Disable the SPI1 Receive interrupt */
      SPI_I2S_ITConfig(SPI1, SPI_I2S_IT_RXNE, DISABLE);
  * @retval None
  /* Infinite loop */
  while (1)
#endif
several pictures of my project:
the circuit doesn't work. I don't know why! My Saleae logic shows me this:
figure4
What's the problem?
Edit: I changed the codes and Now they work better! the first problem was that I forgotten to high and low the NSS pin. I changed the code and now it works better than before. as you can see in Saleae, the data is odd (in other word, it's not "Rohalamin").
  • \$\begingroup\$ After a quick glance at your code I didn't find any assignments of SPI pins to SPI alternate function \$\endgroup\$ – Ashton H. Jul 19 '14 at 0:56
The GPIO pins that you are using for SPI communication should be assigned for the SPI alternate function. For example, the following code will assign Pin5 of PORTA to SPI AF:
GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1);
The same assignment has to be made for all the SPI pins that you are using (MISO, MOSI, SCK, NSS)
  • \$\begingroup\$ I couldn't find such function in HAL library of both MCU. note that the HAL lib of MCUs isn't the same (Cortex-M series of STM32). then your answer is incorrect. \$\endgroup\$ – Roh Jul 19 '14 at 3:36
  • \$\begingroup\$ What library are you referring to? Are you using library from ST? I've just checked STM32F0 Standard Peripheral Library from ST and it does contain function GPIO_PinAFConfig. \$\endgroup\$ – Ashton H. Jul 19 '14 at 15:23
  • \$\begingroup\$ In fact, I use STM32CubeMX (it's a free program from the ST for configure your MCUs) and it uses the STM32Cube_FW_F0_V1.0.0 that content the HAL library V1.0.1 from ST for itself. I checked the GPIO header and source file for find this API but I couldn't find. totally I doubt that it need to that function that you mentioned. Also I found that API in STM32F0xx_StdPeriph_Lib_V1.3.1 \$\endgroup\$ – Roh Jul 19 '14 at 16:33
  • \$\begingroup\$ If you don't configure GPIO pins properly, your SPI will not function at all, unless it is somehow taken care of by HAL. You can refer to the datasheet page 27 of your uC for more details. For the function I've mentioned take a look here. I am aware of CubeMX but never worked with it. As far as I know it uses the same StdPeriphLibrary from ST. \$\endgroup\$ – Ashton H. Jul 19 '14 at 18:02
  • \$\begingroup\$ By the way, ST has lots of SPI examples and you can have a look at the source code and GPIO initialization routine. \$\endgroup\$ – Ashton H. Jul 19 '14 at 18:03
You are getting some data transfer according to your logic analyzer, so you can't be too far off. Assuming it's not just a simple wiring fault, it's likely to be the bus configuration.
SPI has various different configuration options - whether the data is sent on the rising or falling edge of the clock, and where abouts in the clock cycle it should be sampled. Make sure that what you have configured on your microcontroller matches what the slave device expects. See the data sheet for the slave device, and "mode numbers" here, to select the correct CLKPPolarity and CLKPhase. Also make sure that the clock rate you've chosen is not higher than the slave can support.
You need to make sure that the logic analyzer software is configured in the same way, too, by clicking on the little cog icon on the right. Finally, just in case you don't know: the logic analyzer may start capturing in the middle of a byte, so you may need to tell it where a byte starts. Do this by clicking on the underlined "T1" on the right, then clicking at the start of a byte in the graph.
  • \$\begingroup\$ Thanks for help, I have changed the question because I found the first problem. look at the question again. \$\endgroup\$ – Roh Jul 17 '14 at 7:21
