I am trying to simulate a FSM using vector simulator... the state machine variable is called "Tstep_Q", I added it to waveform editor... however, when I start the functional simulation all signals are displayed and change over time except the Tstep_Q signal!! It stays Undefined. While I was trying to resolve this issue I noticed that the simulator is throwing a warning says: "Warning: Tstep_Q - signal not found in VCD." I managed to solve another signal had the same problem "incr_PC" by using the directive /* synthesis keep */, but that was just a regular signal, not a FSM.
module proc_enhanced (Clock, DIN, Resetn, Run, Done, ADDR, DOUT, W);
    input [8:0] DIN;
    input Resetn, Clock, Run;
    output reg Done;
    output [8:0] ADDR;
    output [8:0] DOUT;
    output W;
    // FSM variables
    parameter T0 = 3'b000, T1 = 3'b001, T2 = 3'b010, T3 = 3'b011, T4 = 3'b100;
    reg [2:0] Tstep_Q, Tstep_D;
    // Instructions
    parameter mv = 3'b000, mvi = 3'b001, add = 3'b010, sub = 3'b011,
    ld = 3'b100, st = 3'b101, mvnz = 3'b110;
    // Registers and Wires
    wire [8:0] BusWires;
    wire [2:0] I;
    wire [8:0] IR;
    wire [8:0] R0, R1, R2, R3, R4, R5, R6, R7;
    wire [8:0] A, G;
    reg IRin;
    reg [7:0] Rin;
    reg [7:0] Rout;
    reg Ain;
    reg Gin;
    reg Gout;
    reg DINout;
    reg AddSub;
    wire [7:0] Xreg, Yreg;
    wire [8:0] adr_subr_out;
    reg incr_PC /* synthesis keep */;
    reg ADDRin;
    reg DOUTin;
    reg W_D;
    // Registers
    regn reg_IR (DIN, IRin, Clock, IR);
    regn reg_0  (BusWires, Rin[0], Clock, R0);
    regn reg_1  (BusWires, Rin[1], Clock, R1);
    regn reg_2  (BusWires, Rin[2], Clock, R2);
    regn reg_3  (BusWires, Rin[3], Clock, R3);
    regn reg_4  (BusWires, Rin[4], Clock, R4);
    regn reg_5  (BusWires, Rin[5], Clock, R5);
    regn reg_6  (BusWires, Rin[6], Clock, R6);
    // regn reg_7   (BusWires, Rin[7], Clock, R7); This is replaced with the Program Counter (PC).
    regn reg_A  (BusWires, Ain, Clock, A);
    regn reg_G  (adr_subr_out, Gin, Clock, G);
    regn reg_ADDR (BusWires, ADDRin, Clock, ADDR);
    regn reg_DOUT (BusWires, DOUTin, Clock, DOUT);
    regn reg_W (W_D, 1'b1, Clock, W);
    defparam reg_W.n = 1;
    // Program Counter
    counter PC (Clock, Resetn, Rin[7], incr_PC, BusWires, R7);
    assign I = IR[8:6];
    dec3to8 decX (IR[5:3], 1'b1, Xreg);
    dec3to8 decY (IR[2:0], 1'b1, Yreg);
    // FSM State Table
    always @ (Tstep_Q, Run, Done) begin
        case (Tstep_Q)
            T0:
                if(!Run) Tstep_D = T0;
                else Tstep_D = T1;
            T1:
                Tstep_D = T2;
            T2:
                if(Done) Tstep_D = T0;
                else Tstep_D = T3;
            T3:
                Tstep_D = T4;
            T4:
                Tstep_D = T0;
            default: Tstep_D = 3'bxxx;
        endcase
    end
    // FSM Flip-Flops
    always @ (posedge Clock, negedge Resetn)
    begin
        if (~Resetn)
            Tstep_Q = T0;
        else
            Tstep_Q = Tstep_D;
    end
    // FSM outputs
    always @(Tstep_Q or I or Xreg or Yreg)
    begin
        // initial values
        IRin = 1'b0;
        Rin = 8'b0;
        Rout = 8'b0;
        Gin = 1'b0;
        Gout = 1'b0;
        Ain = 1'b0;
        DINout = 1'b0;
        AddSub = 1'b0;
        Done = 1'b0;
        incr_PC = 1'b0;
        ADDRin = 1'b0;
        DOUTin = 1'b0;
        W_D = 1'b0;
        case(Tstep_Q)
            T0:
            begin
                Rout[7] = 1'b1; // Program Counter
                ADDRin = 1'b1;
            end
            T1:
            begin
                IRin = 1'b1;
                incr_PC = 1'b1;
            end
            T2:
                case(I)
                    mv:
                    begin
                        Rin = Xreg;
                        Rout = Yreg;
                        Done = 1'b1;
                    end
                    mvi:
                    begin
                        DINout = 1'b1;
                        Rin = Xreg;
                        Done = 1'b1;
                    end
                    add, sub:
                    begin
                        Rout = Xreg;
                        Ain = 1'b1;
                    end
                    ld:
                    begin
                        Rout = Yreg;
                        ADDRin = 1'b1;
                    end
                    st:
                    begin
                        Rout = Xreg;
                        DOUTin = 1'b1;
                    end
                    mvnz:
                    begin
                        if (&G != 1'b0) begin
                            Rout = Yreg;
                            Rin = Xreg;
                            Done = 1'b1;
                        end
                    end
                endcase
            T3:
                case(I)
                    add:
                    begin
                        Rout = Yreg;
                        Gin = 1'b1;
                    end
                    sub:
                    begin
                        Rout = Yreg;
                        Gin = 1'b1;
                        AddSub = 1'b1;
                    end
                    ld:
                    begin
                        DINout = 1'b1;
                        Rin = Xreg;
                        Done = 1'b1;
                    end
                    st:
                    begin
                        Rout = Yreg;
                        ADDRin = 1'b1;
                        W_D = 1'b1;
                        Done = 1'b1;
                    end
                endcase
            T4:
                case(I)
                    add, sub:
                    begin
                        Gout = 1'b1;
                        Rin = Xreg;
                        Done = 1'b1;
                    end
                endcase
        endcase
    end
    // Adder/Substractor
    assign adr_subr_out = (AddSub == 0) ? (A + BusWires) : (A - BusWires);
    // Multiplexer
    wire [9:0] MUXsel;
    assign MUXsel[9:2] = Rout;
    assign MUXsel[1] = Gout;
    assign MUXsel[0] = DINout;
    mulpxr bus_multiplexer (MUXsel, DIN, G, R0, R1, R2, R3, R4, R5, R6, R7, BusWires);
endmodule
module mulpxr (sel, DIN, G, R0, R1, R2, R3, R4, R5, R6, R7, BusWires);
    input [9:0] sel;
    input [8:0] DIN, G, R0, R1, R2, R3, R4, R5, R6, R7;
    output reg [8:0] BusWires;
    always @ (*)
    begin
        case (sel)
            10'b0000000001: BusWires = DIN;
            10'b0000000010: BusWires = G;
            10'b0000000100: BusWires = R0;
            10'b0000001000: BusWires = R1;
            10'b0000010000: BusWires = R2;
            10'b0000100000: BusWires = R3;
            10'b0001000000: BusWires = R4;
            10'b0010000000: BusWires = R5;
            10'b0100000000: BusWires = R6;
            10'b1000000000: BusWires = R7;
            default: BusWires = 9'bxxxxxxxxx;
        endcase
    end
endmodule
module regn (R, Rin, clock, Q);
    parameter n = 9;
    input [n-1:0] R;
    input Rin, clock;
    output reg [n-1:0] Q;
    always @(posedge clock)
        if (Rin)
            Q <= R;
endmodule
module dec3to8 (W, En, Y);
    input [2:0] W;
    input En;
    output reg [7:0] Y;
    always @(W or En)
    begin
        if (En == 1)
            case (W)
                3'b000: Y = 8'b00000001;
                3'b001: Y = 8'b00000010;
                3'b010: Y = 8'b00000100;
                3'b011: Y = 8'b00001000;
                3'b100: Y = 8'b00010000;
                3'b101: Y = 8'b00100000;
                3'b110: Y = 8'b01000000;
                3'b111: Y = 8'b10000000;
            endcase
        else
            Y = 8'b00000000;
    end
endmodule
module counter (clk, reset, load, en, D, Q);
    input clk, reset, load, en;
    input [8:0] D;
    output reg [8:0] Q;
    always @ (posedge clk)
    begin
        if (~reset) Q = 9'b0;
        if (load) Q = D;
        if (en) Q = Q + 9'b1;
    end
endmodule
Any clue would be appreciated... I have been trying to figure it out tow days ago!!
  • \$\begingroup\$ I'd say that including your source code is necessary to help you out. \$\endgroup\$ Jul 16, 2014 at 7:42
  • \$\begingroup\$ @VladimirCravero There you have it. \$\endgroup\$ Jul 16, 2014 at 10:49
  • \$\begingroup\$ Did you try to add the directive also to Tstep_Q? \$\endgroup\$ Jul 16, 2014 at 10:59
  • \$\begingroup\$ @VladimirCravero Yes I did try, and was useless... since it is parsed into a state machine maybe. \$\endgroup\$ Jul 16, 2014 at 11:02
  • \$\begingroup\$ well that's strange, I made some FSM with quartus and never had this problem, just wait for someone who can help better than I can. \$\endgroup\$ Jul 16, 2014 at 11:35
Looks like it is a problem with Quartus II software. I am using version 13.1, other versions may have this issue resolved. Same question posted here and solved it by configuring the waveform editor to use Quartus II Simulator rather than ModelSim (which is the default).
