  • The chip is 3mm by 3mm (10 lead)
  • My printers max DPI is 1200dpi
If etching isn't possible, are the MSOP breakout boards on eBay an option? The breakout boards dimension says 1.25mm between the two sides, but this chip says 1.68mm. There is a metal pad on the bottom - does that mean I can't use this?
    \$\begingroup\$ Very likely the chip will need the exposed pad to be soldered, either for cooling or proper grounding. \$\endgroup\$
    – DoxyLover
    Jul 16 '14 at 2:33
I'd say yes, you can make your own boards with that fine of detail, if you have a bit of practice.
For the thermal pad, simply modify it to extend out from under the chip so you can touch it with your soldering iron during assembly. Yes, it's ok to do that. I hand solder all of my home projects, and I do a lot of home projects. For instance, I did that for the following package modified for hand soldering, it worked beautifully.
Those break out boards look like they would short out on the thermal pad, I wouldn't buy them unless they have a version with the thermal pad.
