I am sorry to ask this question, which I believe is very basic, but I cannot find an answer. The following example clearly works. But I would like to omit the declaration of the wires ay and by.
module sub(output reg y);
endmodule
module top(input wire sel,output wire x);
wire ay,by;
sub a(.y(ay));
sub b(.y(by));
assign x= sel ?ay:by;
endmodule
Modules have a names. It is possible to address their ports directly? if yes, what is the correct syntax? This does not work (in Quartus)
endmodule
sub a();
sub b();
assign x= sel ?a.y:b.y;
endmodule
No, it's not possible to do this.
The module.wire syntax works in some systems, but all the synthesis tools will require you to use the ports properly.
  • \$\begingroup\$ thank you. what are the instance names used for then? just for reports? \$\endgroup\$ Jul 16 '14 at 10:41
  • \$\begingroup\$ They're used whenever you need to identify a particular instance, such as in SDC constraints. They get used when exporting to other file formats too. \$\endgroup\$
    – pjc50
    Jul 16 '14 at 11:18
Wire declarations can be omitted and in most case a 1 bit wide wire will be implied. This is generally considered bad practise as you will end up with width mismatches if you forget to declare those wider than 1 bit.
endmodule
//wire ay,by; No wire declaration
sub a(.y(ay)); //1 bit wide wire implied
sub b(.y(by));
endmodule
Unconnected outputs will be optimised away by synthesis.
  • \$\begingroup\$ thank you, however my purpose was omitting the connection in the module instantation. \$\endgroup\$ Jul 16 '14 at 10:42
  • \$\begingroup\$ Why would you want to do that? any way no you can not and would lead to really bad programming practise. Verilog describes hardware and how it is connected. \$\endgroup\$ Jul 16 '14 at 11:22
    \$\begingroup\$ for the same reason that if you have a struct in c you can access its members by structName.member \$\endgroup\$ Jul 16 '14 at 15:22
  • \$\begingroup\$ but your describing hardware and connectivity not just functionality. Unless your talking about verification of a design then you have different approaches. \$\endgroup\$ Jul 16 '14 at 17:26
