I want to set internal oscillator for pic16f628a, according to datasheet page 96, I have to set FOSC_INTOSC, but I get this error main.c:11: error: undefined symbol "FOSC_INTOSC"
if I set the other option FOSC_HS or FOSC_LP or FOSC_XT it works fine (no error)
but it's not working with FOSC_RC and FOSC_INTOSC .it's not because for FOSC_RC and FOSC_INTOSC, there is two possible value for both of them (page 96 datasheet)?????
code :
#include<htc.h>
#include <pic.h>
#include <pic16f628a.h>
// Config word
__CONFIG(FOSC_INTOSC & WDTE_OFF & PWRTE_ON & CP_OFF);
// Define LED pin
#define LED  RA0
// Define CPU Frequency
// This must be defined, if __delay_ms() or
// __delay_us() functions are used in the code
#define OSC 4
// Main function
void main()
        TRISA0 = 1;                // Make RA0 pin output
        TRISB = 1;
        LED    = 0;                // Make RA0 low
    while(1)
        LED = 0;               // LED off
        LED = 1;               // LED on
  • \$\begingroup\$ Try FOSC_RC and se how it goes, I think some compilers use that instead of FOSC_INTOSC. \$\endgroup\$
    – PeterJ
    Commented Jul 16, 2014 at 11:04
  • \$\begingroup\$ same error for FOSC_RC, I think because for FOSC_RC and FOSC_INTOSC there is two possible value for both of them (page 96 datasheet) \$\endgroup\$ Commented Jul 16, 2014 at 11:06
Find the appropriate #include file that your compiler is using for the particular chip you are using and look at it. That's the only way to be 100% sure what is (supposed to be) going on.
For example, here is a snippet from a HTC include file pic16f628a.h:
// INTOSC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OS/CLKIN
#define FOSC_INTOSCCLK       0xFFFD
// INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
#define FOSC_INTOSCIO        0xFFFC
// EC: I/O function on RA6/OSC2/CLKOUT pin, CLKIN on RA7/OSC1/CLKIN
The constant names are sometimes changed by the compiler supplier, and you may even find errors in the files, especially for very new chips.
    \$\begingroup\$ yes it works, thanks a lot, specialty for this advice :) \$\endgroup\$ Commented Jul 16, 2014 at 11:21
  • \$\begingroup\$ I succeed to set internal oscillator as you said, but sill nothing work on my previous question electronics.stackexchange.com/questions/121311/… , I just mad it like shown in the scheme, RA1 cant blink led, and RB5 RB6 RB7 even that they are set input, they turn on the led. \$\endgroup\$ Commented Jul 16, 2014 at 12:09
  • \$\begingroup\$ Did you follow my comment and set CMCON to 0x07?? This is not optional. \$\endgroup\$ Commented Jul 16, 2014 at 12:10
  • \$\begingroup\$ now when I set CMCON = 0x07; the RB5 RB6 RB7 stop turning on the led but RA1 still not working. one answer told me You must put a pull-up resistor to VDD on the MCLR pin, but even like that it's not working \$\endgroup\$ Commented Jul 16, 2014 at 12:22
  • \$\begingroup\$ You should get it to work on simulation (MPSIM) before burning it to the chip. Save yourself a lot of frustration. \$\endgroup\$ Commented Jul 16, 2014 at 12:24
