I recently purchased an Arduino Uno and I've had lots of fun tinkering with it. I'm now interested in measuring the amount of water that flows into my house through the water line.
I'm having trouble finding an appropriate device that will let me measure the flow of water from my well and capture it with my Arduino. Can you guys please recommend a specific component or some general search terms so I can start looking?
Thanks in advance!
    \$\begingroup\$ I am not knowledgeable with arduino but I remember once seeing a video with someone checking water flows w/ arduino. Here is his page johnny.hcssl.iat.sfu.ca/projects/h2o-ware . Any flow sensor/meter will do. \$\endgroup\$ – phwd Mar 28 '11 at 6:05
Seeedstudio sells a flow sensor: http://www.seeedstudio.com/depot/g12-water-flow-sensor-p-635.html?cPath=144_151&zenid=2550fe072947d974a46772da306b7a46
It's probably too small for your application, but it could be a place to start.
  • \$\begingroup\$ Thanks for pointing that one out to me. And indeed, it looks like a very good place to start out. It appears I'll be able to easily measure water flow through a garden hose, which is, again a great place to start. \$\endgroup\$ – Kevin Mark Mar 28 '11 at 21:37
  • \$\begingroup\$ There's a range of different sized sensors at futurlec.com too. \$\endgroup\$ – Christopher Biggs Mar 28 '11 at 22:38
  • \$\begingroup\$ up to 30 l/min, that's half a liter per second. Doesn't sound like small to me. \$\endgroup\$ – Federico Russo Jun 13 '11 at 13:04
Wikipedia has a page on different methods of measuring water flow. If you wanted to build the sensor yourself, then the ultrasonic flow meter would be probably the easiest.
