I am working with two sensors with 4 pin as output.
My question is simple: I want to make circuit that allows me to short circuit the output of either one of the sensors individually when needed.
I am considering using quad 1:2 demux (AGD774a) and shorting either the pins on channel B together while measuring with channel A and vice versa.
So when I want the channel for normal measurement I will use channel A and when I want output of sensor shorted I change the channel of the switch.
So, my main question is whether using a demux to solve the requirement is a wise choice or there is some other way it can be achieved.
Notes:
The sensor is an ultrasonic transducer which produces only millivolt level outputs.
In use the sensor is placed in a heating chamber to increase its temperature.
When the temperature of the transducer is varied, it produces spurious temperature-change related voltages.
After heating we need to short the output pins to release all the residual voltage.
The charge itself is small.May be I can do a worst case calculations and attach a resistance as well with it.
The voltage drop is small - in the mV range.
I do not think that an electromechanical relay is required.The sensor will not be connected to Micro-Controller.
Shorting is needed to discharge the piezo in the sensor which occurs when the temperature is changed.
