This isn't homework, it's just a review problem. The answer is 4mW. I tried working the problem and came up with the wrong answer. What did I do wrong, and how can I solve this correctly?
My steps:
- Remove \$R_L\$ and create an open in its place
- Find the voltage at the open, this is the open circuit voltage
- I applied KCL at node 2 (what I labeled V2)
- 6/3k amps in, 2mA out, 2mA in, and thus the current going out through the 6k ohm resistor (center branch) is 2mA. 2mA * 6kohms = 12 V across the 6kohm resistor.
- Also, there is 4V going across the 2kohm resistor.
- 12 + 4 = 16, so the open circuit voltage is 16V.
- Opening the voltage source and shorting the current source, the internal resistance is 6k ohms (2k ohm is ignored, no current flow, and 3kohm is ignored, no current flow)
- The Thevenin equivalent circuit has a 16V source, 6kohm internal resistance, and 6kohm load R_L. The voltage divides evenly. So, 8V/6kohms = 1.3mA through RL
- P=IV, 1.3mA * 8V = 10.667 mW
What did I do wrong?
