I have a 12V DC motor that I plan to run in one direction with PWM input at 21A. However, in the other direction I want to drop the voltage to limit the speed. Ideally. the regulator would sit between the motor controller and the motor. The current draw is no more than 8A in this direction. What is a robust voltage regulation solution that can handle a nasty PWM input at relatively high current?
Alternatively, how could I limit the duty cycle of the PWM in one direction with hardware given the above conditions?
    \$\begingroup\$ Your question doesn't make sense. If you're already doing PWM, then I don't see why you need any additional voltage regulation beyond altering the PWM duty cycle accordingly. What is the extra regulation for? \$\endgroup\$ Jul 17, 2014 at 21:06
PWM in itself is regulation. You need an h-bridge if two direction rotation is needed and if you do not have (+ve)-GND-(-ve) power configuration available.
The robust design will use switching devices (possibly MOSFETs) with proper rating (with overload overhead) and inductor kick suppression (mostly already inside the MOSFETs) when you disconnect the pulsed power. Plus protection in the case electronics want to fry the metal, ceramics and plastic. ;)
PWM is filtered (averaged to DC) by the inductance of the motor coils but that has less to do the real performance; the real motor speed is the combined effect of the filtering of PWM and its moment of inertia. A motor with enough moment of inertia will filter out the PWM pulses mechanically if not done electrically.
You need one duty factor for PWM in one direction and another duty factor in the other direction.
  • \$\begingroup\$ Missing "not" in opening line methinks. \$\endgroup\$
    Jul 18, 2014 at 9:28
  • \$\begingroup\$ If two direction rotation is needed, you need polarity reversal. If you do not have (+ve)-GND-(-ve) power configuration available, you need an h-bridge that will allow you to combine PWM with the ability of polarity reversal. \$\endgroup\$
    – nvd
    Jul 18, 2014 at 9:40
