13
There is a proposed design that could have a polyfuse tripping many times. Is there any lifetime to these things? Number of resets? I looked here but could find no such spec.
I'm a little worried by the design... but perhaps needlessly.
I'll send Littlefuse an email and ask there too.
I got a nice Qualification Report back from Littelfuse. (nice fast response, +1 for Littelfuse.)
It's not clear if I can share this document on line; I've asked for permission. There is a nice graph showing a linear increase in the fuse resistance with the number of trips, about a doubling of resistance after 200 events (mean resistance went from 0.1 Ω to 0.25 Ω after 300 trips). I assume that the trip current will decrease as the resistance increases... but there is no data showing that.
And here's something else. The resistance increases if the device is left in the trip state. This does not look linear, but again resistance increased from 0.1 Ω to 0.25 Ω if left tripped for 24 hours.
My conclusion: These devices should not be used as repeatable current limiters, but only as fault detectors.
  • \$\begingroup\$ I disagree with your conclusions. A doubling of 100mΩ for a fuse should not matter in 99% of designs. What is your application where you're expecting the fuse to trip so often? \$\endgroup\$
    – ACD
    Jul 18, 2014 at 15:48
  • \$\begingroup\$ Definitely interested to hear if it is possible to use these as 'repeatable current limiters', if you're allowed to share info from the report, please do. \$\endgroup\$
    – jjmilburn
    Jul 18, 2014 at 15:53
  • \$\begingroup\$ @ACD, A somewhat poorly designed magnetic field coil, which melts if left at full current.. The PTC allowed for temporary operation at an full current to get data... So the PTC was speced pretty close to the edge. A moving edge will be bad. \$\endgroup\$ Jul 18, 2014 at 16:35
  • \$\begingroup\$ @jjmilburn, Sorry I can't share. :^( \$\endgroup\$ Jul 18, 2014 at 16:35
    \$\begingroup\$ @ACD, Well I'm making the assumption that the trip point will also change with the resistance. This seems reasonable, but if you have information that it doesn't then do share. So it trips when it gets too hot. How hot it gets depends on the current and the resistance. (and then the environment) If the resistance doubles that means the trip point current goes down by sqrt(2)...(I^2 * R) So instead of tripping at 3 amps (say) it's nearer 2. With a commensurate change in all the tripping times. \$\endgroup\$ Jul 18, 2014 at 19:33
11
  • Raychem indicate that rapidly cycled polyfuses do have a finite cycle lifetime.
See the diagram below, taken from the useful [PolySwitch PPTC Device Principals of Operation] (sic) seems likely to be similar to the Littlefuse document which you are not permitted to share - maybe this is why :-). The original link is broken as of August 2022. A less readable but adequate version is here.
As Tyco / Raychem publish this curve publicly they may be a better source of information on lifetime and cycling, even though not the brand you were working with.
The term "extended" here suggests to me that they consider 1000+ cycles a non-standard application. I do not know what "rapid" means in this context.
As trip point is closely related to device temperature (and can be affected by eg thermal effects of adjacent contacting metalwork, PCB track thermal characteristics and air flow) then it is essentially certain that trip current will decrease as on resistance rises. As noted by others, as power dissipation is related to I^2.R and as I is established by external circuit elements, it looks likely that trip current would start to fall from about 750 cycles onwards for the example in the graph.
The Polyswitch or Polyfuse was invented by Raychem Corporation (now TE Connectivity).
How well their data applies to competitors products is uncertain but components using the same basic principal seem liable to share somewhat similar characteristics, including cycle lifetime.
Related:
This does not directly answer the lifetime question but may help with the cumulative effects (or lack thereof) of multiple trips.
My understanding based on material referenced below + prior understanding is:
  • Polyfuses consist of a matrix of an electrically conductive material embedded in an electrically non conductive polymer binder.
Heating of the PF to a trip temperature (typically 125 C)
  • causes the binder to expand due to melting of crystalline structures in the polymer
  • so that they assume an amorphous state which has a higher physical volume,
  • so that the material expands and
  • the conductive material to begin to separate due to physical separation of the conductive particles
  • so that resistance increases, and
  • self-heating increases in a regenerative manner such that
  • a small holding current is enough to maintain the PF in the "tripped" high resistance state.
    When holding current is removed the device cools and contracts.
Cooling and contraction is a thermo-mechanical process. Initial return to a low resistance state occurs within seconds to tens of seconds due to temperature drop but a complete return to initial resistance due to recrystallisation may take days weeks or months.
There is some maximum resistance value "Rimax" that a device will assume post reset under standard test conditions* that can be used as a maximum design parameter.
(* Measure after the device has been depowered for one hour post-trip.)
Resistance post-trip will be "reset" to some value > Rinitial and <= Rimax after each trip, but apart from this, increases are non-cumulative with multiple trips. In view of the Raychem curve at the top of this post, that conclusion seems liable to be true for only a 'sensibly small' number of cycles
[for selected and limited values of "sensibly" :-) ].
Based on
This March 2013 Stack Exchange question (serendipitously discovered with a web search)covers similar but not identical material. PTC fuse resistance characteristic?
The question contained a link to this utterly superb 2008 13 page Tyco document
Fundamentals of PolySwitch Overcurrent and Overtemperature Devices
While the document is Tyco focused it contains much general material.
Material on page 4 starting "Reflow and trip jump (Rimax) " is of likely relevance.
They note
  • PolySwitch devices exhibit some resistance hysteresis when tripped, either through an electrical trip event or through a thermal event such as reflow. This hysteresis is observed as a resistance increase over the as-delivered resistance of the PolySwitch device. Figure 4 shows typical behavior for a PolySwitch device that is tripped and then allowed to cool. In this figure, we can clearly see that even after a number of hours the device resistance is still greater than the initial resistance. Over an extended period of time, the resistance will continue to fall and will eventually approach the initial resistance.
However, since this time can be days, months, or years, it is not practical to expect that the device resistance will reach the original value for operational purposes. Therefore, when PolySwitch devices are being developed, this "trip jump" or "reflow jump" is taken into consideration when determining the hold current. This increase in resistance is defined as R1MAX and is measured one hour after the thermal event.
It should be noted that these trip jumps are non-cumulative over sequential trip events.
BUT, as above, "In view of the Raychem curve at the top of this post, that conclusion seems liable to be true for only a 'sensibly small' number of cycles
[again, for selected and limited values of "sensibly" :-) ]."
I understand the reference to resistance measurement one hour after tripping NOT to mean "with power still applied", but the resistance after having "settled" in an unpowered state for one hour after having been tripped.
http://www.ttiinc.com/docs/IO/6867/raychem.pdf
http://en.wikipedia.org/wiki/Resettable_fuse
Littelfuse 0805 products
Littelfuse 1206L series
Littelfuse 1210L series
Littelfuse 60R series
Littelfuse Poly-fuse home page
Littelfuse Polyfuse selection guide
  • \$\begingroup\$ That answer is very good. We need to be aware of how to use it, basically there are two: Charging of capacitor and Failure mode (>50,000 cycles Vs >100 cycles. See: mouser.com/datasheet/2/136/…). \$\endgroup\$ Nov 15, 2020 at 19:26
8
For a design demanding a large number of cycles from a PTC, the term to look for is switching PTC. For instance, these EPCOS switching PTCs are designed for 30,000 cycles.
At a higher price point, clamped PTC ceramics have free contact motion when heating up, permitting between a quarter million and a million switching cycles.
In contrast, these Bourne SMD PTCs are rated at a mere 100 cycles.
There may be SMD switching PTCs existent if through-hole ones are not convenient, but a cursory search did not throw out any meaningful results, YMMV.
  • \$\begingroup\$ Thanks @AnindoGhosh, From a quick search it seems like both the resetable fuses and inrush current limiters are of the switching PTC type. (As opposed to a more linear thermistor used for temperature sensor.) Do you have a link or better name for the more costly clamped PTC ceramics? I can't seem to find them (google and Digikey search.) \$\endgroup\$ Jul 18, 2014 at 17:06
  • \$\begingroup\$ Please check Vishay, IIRC they had a few such. \$\endgroup\$ Jul 18, 2014 at 18:46
  • \$\begingroup\$ This response needs to be better evaluated, not to compare different parameters of similar components. One might think of buying from a specific brand due to incorrect data evaluation, but they may be making the wrong choice. Two conditions of use are presented: Charging of capacitor and Failure mode. We cannot compare one condition with the other. If you consider only the lowest service life (Failure mode >100 cycles), both components can be similar, Although some manufacturer may not be specifying that it is this type of condition (Failure mode). \$\endgroup\$ Nov 15, 2020 at 19:22
PTCs are not designed for "high" number of trip/recover cycles. After some thousands of cycles the degradation is often visible to naked eye inspection. Parameters are moving away from their original values and total failures are more and more probable.
However one of the right questions is that what is the alternative. Is it really a problem to have this limitation? When an objectively more reliable regular fuse blows, the device itself will cease to function - reducing the reliability of the device itself.
In my short design experience with PTCs is that most of the time I could make a decision more easily considering the part vs device reliability dilemma. In my use-cases the device reliability statistics were more important, but I can easily imagine use-cases when the result of this decision points away from PTCs.
A nice article about this topic: https://www.prognostics.umd.edu/calcepapers/10_Shunfeng_Cheng_Failure_Precursors_for_Polymer_Resettable_Fuses.pdf
