DS2401 is a 64-bit ROM memory that used as a hardware-serial-number. [Datasheet : here] It has only two pin. One of them is ground and one of them is Data/Power pin. So for communicate with this chip there is a protocol that called 1-Wire. [1-Wire tutorial : here and here . ]
I want to read my DS2401 chip with AVR ATmega32 , and I use 1wire.h library in codevision.
As mentioned in Codevision AVR User Manual [Here] I must use w1_read() function to read a byte of DS2401. but it returns me only 255
[On the LCD]!
This is my codevision code:
This program was produced by the
CodeWizardAVR V2.05.0 Professional
Automatic Program Generator
© Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 7/19/2014
Author :
Company :
Comments:
Chip type : ATmega32A
Program type : Application
AVR Core Clock frequency: 1.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 512
#include <mega32a.h>
#include <delay.h>
#include <stdio.h>
// 1 Wire Bus interface functions
#include <1wire.h>
// Alphanumeric LCD Module functions
#include <alcd.h>
// Declare your global variables here
void main(void)
int init_res,read_byte,i;
char read_byte_char[64];
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// 1 Wire Bus initialization
// 1 Wire Data port: PORTB
// 1 Wire Data bit: 2
// Note: 1 Wire port settings must be specified in the
// Project|Configure|C Compiler|Libraries|1 Wire IDE menu.
// w1_init(); <-------------------------
// Alphanumeric LCD initialization
// Connections specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTA Bit 0
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
// Characters/line: 16
lcd_init(16);
while (1)
init_res = w1_init();
if (init_res ==1)
lcd_clear();
lcd_gotoxy(1,0);
lcd_puts("Chip Connected");
delay_ms(1000);
lcd_clear();
lcd_gotoxy(1,0);
lcd_puts("Serial Number:");
for (i=1;i<9;i++)
read_byte=w1_read();
lcd_gotoxy(i,1);
sprintf(read_byte_char,"%i",read_byte);
lcd_puts(read_byte_char);
delay_ms(1000);
else
lcd_clear();
lcd_gotoxy(1,1);
lcd_puts("Chip Not Found");
delay_ms(2000);
Q1: Why?
Q2: Each time that I call w1_read function, DS2401 send me next 1 byte? or the same first 1 byte? or total of the ROM?
