I have question about the analysis of common-mode gain of BTJ differential amplifier with active load on the Sedra Smith book. In this book, the differential-mode gain \$Ad\$ is derived based on the transconductance \$Gm\$ and output resistance \$Ro\$, \$Av=Gm*Ro\$. These are represented in the figure below. enter image description here
Notice transistor \$Q_3\$ which is connected as a diode. In the equivalent circuit, \$Q_3\$ is represented as the resistance (\$r_{e3}\$//\$r_{o3}\$). Where \$r_{e3}\$ represents the resistance viewed from the emitter, and \$r_{o3}\$ is the Early resistance of \$Q_3\$.
Now for common-mode analysis, we have the following equivalent circuit for determining the gain. Notice now that the diode transistor \$Q_3\$ is represented by the resistance (\$r_{e3}\$//\$r_\pi\$//\$r_{03}\$), where \$r_\pi\$ is the input resistance of \$Q_3\$.
My questions are: Why is \$r_\pi\$ used to represent \$Q_3\$ in common-mode? Is it ok to use (\$r_{e3}\$//\$r_\pi\$//\$r_{o3}\$) for differential-mode too? enter image description here
Without more context, I can't answer the question of why different expressions are used but do note that
$$r_e = \frac{1}{g_m}||r_{\pi}$$
so the expressions are, in fact, equivalent.
To see this, recall
$$r_{\pi}= \frac{\beta}{g_m}$$
Thus,
$$\frac{1}{g_m}||r_{\pi} = \frac{r_{\pi}}{\beta}||r_{\pi} = \frac{r_{\pi}}{1 + \beta} = r_e$$
