I have a sine wave signal centered around 2.5 volts (1/2 Vcc) in which I require the the upper half only, brought down to 0 volts, so a 2 volt peak-to-peak input around 2.5V would become a half sine wave from 0 - 1 Volts.
I have tried a subtracting amplifier configuration to simply subtract the DC level from the sin wave but this introduces a 0.5 volt to 1 volt DC offset onto the output signal or generates spikes at the start of the output waveform depending on what op amp I use.
Hopefully someone can help or I may have to re-think my design completely.
/******************** Additional information ********************/
Here is the initial schematic I had for this circuit,
The input sine wave of variable amplitude but centred around 2.5 Volts.
R1 and C2 low pass filter the signal at 0.1 Hz to get the DC level which is then buffered by IC1B and used as a reference for all the other operations
IC1A inverts the original signal around the DC level
IC2A and B then subtract the DC level from the inverted and non inverted versions of the signal.
Monitoring the points between sections of the circuit on an oscilloscope showed the expected values at all points except Out A and Out B, which had waveforms as shown in the link below.
the peaks of the waveforms when using a normal LM358 op amp were correct but there seemed to be a 0.5 - 1 Volt floor on the signal, trying an OPA2333 rail to rail op amp as IC2 gave the third waveform with a large spike at the initial phase of the signal which is not really desirable.
unfortunately adding the following active rectifier circuit prior to R4 and R10 did not have any effect on the output with an LM358 and I then managed to kill my only OPA2333 amplifier so can't test if it would have any effect on that.
the signals from Out A and Out B will be used to drive power transistors to source the two halves of a centre tapped transformer.
