Based on CST website, they claim that CST PCB Studio can import Altium files.
But when I open Import on CST , it gives me just these options :
CST PCB Studio Import
I tried to Export Altium to HyperLynx and Import it to CST PCB Studio,but it gave error too. I also tried converting to AutoCAD and use ODB++ , but still gives error for importing.
I'm using CST Suite Studio,Release version 2014.00 - Feb 24 2014
Do you have any solution ?
Thanks.
  • \$\begingroup\$ Are you sure you're using the latest CST? It could be a new facility. \$\endgroup\$ Jul 26, 2014 at 9:58
  • \$\begingroup\$ I'm using CST Suite Studio,Release version 2014.00 - Feb 24 2014. \$\endgroup\$
    – AliRezza
    Jul 26, 2014 at 10:09
    \$\begingroup\$ Altium isn't an option! Try using something else. \$\endgroup\$ Jul 26, 2014 at 10:59
    \$\begingroup\$ I found the solution, In Altium , I went to File > Fibraction Outputs > ODB++ and exported in this way. Now it can easily imported via CST. \$\endgroup\$
    – AliRezza
    Jul 26, 2014 at 11:06
    \$\begingroup\$ @LeonHeller - You should tell that to all the places I consult for. I think they'd disagree. \$\endgroup\$ Jul 26, 2014 at 11:53
  • \$\begingroup\$ I confirm that ODB++ is the best option when you have to export a design from a PCB layout tool and use it on a EM simulator or SI tool. \$\endgroup\$
    – RodezIO
    Nov 16, 2017 at 12:59
