i know the circuit. I implement it using verilog and it giving result correct. like when we have to design any digital circuit we draw truth table. Optimize circuit using K-map and then implement. In case of edge trigger Flip flop( i am considering the easiest flip flop i.e. D flip flop) . How we draw its circuit using gates?
Negative Edge trigger D flip flop
closed as unclear what you're asking by tcrosley, Michael Karas, Matt Young, Rev1.0, Vladimir Cravero Jul 28 '14 at 9:51
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ I don't understand. If you know the circuit and you can implement it in verilog, then what's the question? \$\endgroup\$ – clabacchio Jul 27 '14 at 20:04
  • \$\begingroup\$ how this respond only to Falling negative edge. The falling negative edge consider as 1 or 0 ? \$\endgroup\$ – SW. Jul 28 '14 at 4:26
    \$\begingroup\$ An edge is an edge, neither 1 or 0. If it's falling then it's from 1 to 0. \$\endgroup\$ – clabacchio Jul 28 '14 at 7:25
  • \$\begingroup\$ When clk is in it negative edge then how we determine q? (what is the value of clk that time (0 or 1)) \$\endgroup\$ – SW. Jul 29 '14 at 4:07
    \$\begingroup\$ This can help, especially the part about edge triggered. \$\endgroup\$ – clabacchio Jul 29 '14 at 5:51
