I'm still searching to find an answer for this question:
Why while the stm32 MCUs have a perfect watchdog (I mean Window watchdog (WWDG)), there is a simple watchdog (Independent watchdog (IWDG)) ?
I found this page that has said:
ST Microelectronics has a line of Cortex-M3 devices. The M3 has become extremely popular for lower-end embedded devices, and ST's STM32F is representative of these parts (though the WDT is an ST add-on, and does not necessarily mirror other vendors' implementations). The STM32F has two different protection mechanisms. An "Independent Watchdog" is a pretty vanilla design that has little going for it other than ease of use. But their Window Watchdog offers more robust protection. When a countdown timer expires, a reset is generated, which can be impeded by reloading the timer. Nothing special there. But if the reload happens too quickly, the system will also reset. In this case "too quickly" is determined by a value one programs into a control register.
Another cool feature: it can generate an interrupt just before resetting. Write a bit of code to snag the interrupt and you can take some action to, for instance, put the system in a safe state or to snapshot data for debugging purposes. ST suggests using the ISR to reload the watchdog -- that is, kick the dog so a reset does not occur. Don't take their advice. If the program crashes the interrupt handlers may very well continue to function normally. And using an ISR to reload the WDT invalidates the entire reason for a window watchdog.
and this:
STMicroelectronics' new series of STM32F4 Cortex™-M4 CPUs has two independent watchdogs. One runs from its own internal RC oscillator. That means that all kinds of things can collapse in the CPU and the WDT will still fire. There is also a “window watchdog” (WWDT) which requires the code to tickle it frequently, but not too often. This is a very effective way to insure crashed code that randomly writes to the protection mechanism does not cause a WDT tickle, and the WWDT can generate an interrupt shortly before reset is asserted.
ok, let's to take a look in the reference manual:
The STM32F10xxx have two embedded watchdog peripherals which offer a combination of high safety level, timing accuracy and flexibility of use. Both watchdog peripherals (Independent and Window) serve to detect and resolve malfunctions due to software failure, and to trigger system reset or an interrupt (window watchdog only) when the counter reaches a given timeout value. The independent watchdog (IWDG) is clocked by its own dedicated low-speed clock (LSI) and thus stays active even if the main clock fails. The window watchdog (WWDG) clock is prescaled from the APB1 clock and has a configurable time-window that can be programmed to detect abnormally late or early application behavior. The IWDG is best suited to applications which require the watchdog to run as a totally independent process outside the main application, but have lower timing accuracy constraints. The WWDG is best suited to applications which require the watchdog to react within an accurate timing window.
The window watchdog is used to detect the occurrence of a software fault, usually generated by external interference or by unforeseen logical conditions, which causes the application program to abandon its normal sequence. The watchdog circuit generates an MCU reset on expiry of a programmed time period, unless the program refreshes the contents of the downcounter before the T6 bit becomes cleared. An MCU reset is also generated if the 7-bit downcounter value (in the control register) is refreshed before the downcounter has reached the window register value. This implies that the counter must be refreshed in a limited window.
As you can see, none of them have said that Why there is two watchdog. if I ask that What are the differences between the both watchdog, you will count all features that you can see in the above and if you want compare the both, obviously the Window watchdog (WWDG) will be the winner! then Why there are two watchdog?
I want to know that when should I use IWDG and when WWDG?
and is there any reason that say us Why do they call the second watch by this name -> "Window watchdog"?
