I'd like to create a small device that can tell when it's near another created device or sensor. When it detects the other device, it lights up an LED.
Maybe maximum detection range of a few feet. No need for any unique ID values or complex data exchange, just a simple "Yes I detect one, no I don't" sort of control.
Any suggestions on how this could be done in a low power, portable sort of way? Because its requirements are so simple, something like RFID seems overkill (even if it could be made to work).
You could use a simple Infra-red LED, and a photo diode. You may have to adjust the LED intensity with a potentiometer to calibrate the range.
This will sense proximity providing there is line-of-sight.
  • \$\begingroup\$ Hmm hadn't thought of IR. Have to think about the LOS thing and if that's an issue... \$\endgroup\$
    – Tim Holt
    Mar 30, 2011 at 20:55
  • \$\begingroup\$ Calling this good - thanks for that brain nudge I needed BG100! The first circuit on home.cogeco.ca/~rpaisley4/PhotoDetectors.html (lights when sensing) looks like it would do what I need. \$\endgroup\$
    – Tim Holt
    Mar 30, 2011 at 21:25
  • \$\begingroup\$ @Tim Holt: No problem... \$\endgroup\$
    – BG100
    Mar 30, 2011 at 21:38
