I have many gadgets around the house that I don't use often, recently I notice that a battery failed on an Mp3 player not used for a year. The battery now has a life of 1 minute from the original 5-7 hours.
What would be the maximum amount of time to leave a Li-Ion uncharched that would not make the batteries unusable.
What other considerations should I take if I use rarely a device to be able to still use the battery, should I leave it fully charged, etc ?
  • Optimum temperature: 15 degrees Celsius and even lower
  • Optimum state-of-charge: 40 %
  • Avoid temperatures above 30 degrees Celsius (both during usage and storage)
Note that after 300 to 500 charge/discharge cycles, the battery may never be able to charge at its full capacity.
Here is an useful table:
By Isidor Buchmann. How to Prolong Lithium-based Batteries
Sources: batteryuniversity.com: How to Store Batteries and How to Prolong Lithium-based Batteries
    \$\begingroup\$ batteryuniversity.com is not a reliable source. \$\endgroup\$ Aug 29 '17 at 3:54
