Looking to play around with the CREE Xlamp series LED and was wondering what would I need to drive them off 110V household power?
Output current needs to be in the range of 800-900mA.
EDIT: I am looking to do this for creating lighting for a NanoReef tank. I would be combining several of these in series.
As was suggested twice already you do not want to power this directly from the line. You should have an isolated low voltage supply.
I would use a current-sink to provide a regulated current. An easy way to make a current-sink is to use an op-amp, resistor and FET. I have been working on a prototype that is four channels at 20A per channel. For an LED application the practical limits would be around 2A per channel (due to cooling). A picture of my prototype that is powering 5 1W LEDs is at http://tinyurl.com/yzg9kd7
I have mounted the LEDs on a heatsink. I use thermal grease between the LEDs and heatsink. I have a schematic of a current-sink (a.k.a. load cell) at http://tinyurl.com/6cbn6h (scroll down to the "Electronic Load" section.
I would not advise driving the led directly with household voltage - it is far too high for this low voltage device. A further consideration is that the led requires DC to drive it and the household power is AC.
These LEDs will draw 800-900mA at a forward voltage of around 3.2 v. If you use a wall wart (plug and voltage regulator all in one) with an output of 5v DC (a common value) then a 1.8 ohm 2 watt (or greater wattage) resistor in series with the led would do the trick. Note the led will need a heatsink as it will need to dissipate about 3W.
  • \$\begingroup\$ Good point. On another note: LED replacement bulbs then have the voltage regulator and load resister built in to the housing? \$\endgroup\$
    – jdiaz
    Dec 22, 2009 at 19:37
  • \$\begingroup\$ Edited original question to include more info. \$\endgroup\$
    – jdiaz
    Dec 22, 2009 at 19:47
  • \$\begingroup\$ Yes - led mains voltage bulbs need a rectifier and voltage regulator, they are contained in the bulb package. \$\endgroup\$
    – JohnC
    Dec 22, 2009 at 20:34
At that power I'd use some kind of switching regulator for efficiency.
I wouldn't dare to go directly from household power to the LED without a lot more research. For a start I'd rather use some wall wart to provide say 12V and step that down to the LED.
Also, make sure to cool them sufficiently.
