I trying to control my turntable switch with Arduino. This is a toggle switch with 3 wires one wire is for CW rotation the other one is for CCW and the other cable is main with 240VAC. I am using this relay shield; from this shield I am using two relays with this this connection idea:
So basically one relay is controlling on/off and the other relay will control rotation in CW and CCW. For now I have tried this connection with two 12V LEDs and it's working fine. But now that I need to use my turntable, I think I should connect common of first relay with the main of 240V AC and I am not sure if I can do this or not (how safe it is).
What am I trying to achieve is better described here: Triple pole triple throw relay
The relays on the shield you linked are rated for 7A at 250V AC, but I don't think the relay shield itself is designed for that.
Relay Shield
The product page states:
Cautions:
Place 2 layers of electrical tape on the top of the Arduino's USB connector. This will prevent the relay shield from making contact. Do not operate voltage more than 35V DC.
(Emphasis mine.)
The datasheet for the relays on that board (Heli Shun HLS8L-DC5V) show that the primary coil is 5V 0.36W:
Datasheet
Note that the contact ratings section specifies 250V AC / 30V DC. This immediately makes me question the difference between the relay datasheet (30V DC) and the shield product page (35V DC).
Since you're using AC, this discrepancy might just be a side note. The shield product page doesn't even mention AC for the switching voltage, it just repeats the 35V DC max switching voltage.
Shield Specifications
Based on this, I don't think I would connect 240V AC, because it may be that the PCB isn't designed with the necessary voltage isolation.
Further, since you're not experienced working with mains voltage, which can be extremely dangerous, I don't recommend doing so without the assistance of a professional.
| improve this answer | |
