I currently have a fan with a 4-pin connector that I want to power, but I do not have a power supply with a 4 or 8-pin connection. Is it possible to disconnect this connector piece and connect the individual wires directly? (red and black?)
Update: I gave it a shot and removed the connector piece and hooked up the red/black wires to a power supply. This worked.
  • \$\begingroup\$ You can always remove the connector and connect the individual wires directly. But without knowing what those 4 wires do, you're taking a risk. Did the manufacturer choose red and black as power and ground? Maybe. But maybe not. And what do the other yellow and blue wires do? \$\endgroup\$
    – Dan Laks
    Aug 1, 2014 at 18:43
  • \$\begingroup\$ Yeah, there are no specifications indicating what the 4 wires do, unfortunately. Wondering if there's some sort of industry standard where red+black are power+ground.. \$\endgroup\$
    – M.Y.
    Aug 1, 2014 at 18:48
  • \$\begingroup\$ Common practice, yes. Industry standard, no. Doing a google search for "4 wire fan" came up with this link: pavouk.org/hw/fan/en_fan4wire.html The four wires are power, ground, PWM, and tachometer. If that's what you have, you'll still need to produce a PWM signal to make the fan turn. \$\endgroup\$
    – Dan Laks
    Aug 1, 2014 at 18:55
  • \$\begingroup\$ Thanks! Do I really need the PWM signal? I'm tempted to just try powering it up with the power and ground... Another non-CPU fan that I have consists of just power and ground wires. \$\endgroup\$
    – M.Y.
    Aug 1, 2014 at 19:01
  • \$\begingroup\$ Nevermind.. doesn't seem like it'd work: pcbheaven.com/wikipages/How_PC_Fans_Work \$\endgroup\$
    – M.Y.
    Aug 1, 2014 at 19:07
10
Most fans with a separate PWM-speed-control lead are designed to run at full speed if that lead is left floating. This is a safety measure so that, if the wire comes loose, the system won't overheat due to the fan stopping.
In general, all fans designed for use in PCs use the same wiring. Starting from the black wire, they are Ground/return, +power (almost always 12V but some non-PC fans use other voltages; check the label on the fan), tachometer (wire is grounded by the fan a certain number of times per revolution, usually 2 or 4) and PWM. The PWM wire is always on the end to allow a 4-wire fan to be plugged into a 3-pin connector for either no speed control or PWM control by interrupting the +power pin.
BTW, the link provided in the comment by M. Y., http://pcbheaven.com/wikipages/How_PC_Fans_Work/, with all of its edits, confirms all of this.
  • \$\begingroup\$ Another question.. can I power a THREE-pin fan with the red+black wires? I'm assuming so because there's no PWM control.. but not quite sure. \$\endgroup\$
    – M.Y.
    Aug 7, 2014 at 19:58
  • \$\begingroup\$ Assuming you're talking about a standard PC fan, then yes. The third wire is an output from the fan, tachometer, which can be left floating. \$\endgroup\$
    – DoxyLover
    Aug 7, 2014 at 20:30
If you came here from Google with the question:
How to connect a 4-pin (3-pin) connector to a power supply?
This is for you. The OP asked
I interpret this as "I want to power my fan and have it running at 100% speed".
If you interpret this differently, ask the OP to clarify. Otherwise:
Do you have red and black wires? I don't. I have four black wires on my 4-pin PWM Arctic and Noctura fans because I use my own PWM cables. So, to answer the OP's question and help Googlers years in the future, try this:
Attach a voltmeter to any two adjacent pins/wires (power pins are usually adjacent). Next, with a can of compressed air (not by touching or blowing), get the fan spinning and see if you can observe something close to the 5V, 12V, or 24V (what your fan is rated for). You should only need to try this at most twice. Yes, this works.
Why does this work? If you power a typical (single-phase) DC cooling fan, it spins. If you blow on a fan hard, it produces a voltage. This is how you find your power pins for the 3-pin and 4-pin PWM fans if you want to run them at 100% duty (no PWM signal at all - a floating pin). Nitpickers will nitpick, but this has worked for ages for cooling fans in computers and 3d printers.
You can even pulse the power wires (it is still considered PWM) for low-power fans. This is exactly how 3d printers control their mainboard cooling fan (e.g. BTT SKR mini E3 v3). Although, adding a capacitor across the power lines with a PWM signal is cleaner, but that is another topic.
That is how you 1) find the power pins for a 4-pin PWM fan, and 2) yes, you can power the fan for 100% speed with just two of four pins.
  • \$\begingroup\$ If anyone wishes to nitpick, I humbly ask that you edit the answer directly instead of us getting into a long, drawn-out, comment spree. \$\endgroup\$
    – Drakes
    Jun 10, 2022 at 15:42
