I've read about how current flows and I am confused. I probably don't understand it correctly so I am asking 2 questions
  • If I connect 2 charged sides of battery by copper wire and I touch that wire will electricity travel through me?
  • If the electricity in electric lines doesn't travel to ground(grounded circuit) in normal circumstances, why does it shock me when I touch the line(I thought electricity travels only through path with less resistance)
Is electricity travelling to ground in the picture? enter image description here
Yes, it will.
If the copper wire is carrying some current it means that some voltage is dropping along it, i.e. if you measure the voltage at one point it will differ from the voltage measured on another point. When you touch the wire you are touching it in many points, so that your finger would experience different voltages in different points, hence a current. Please note that this current would be very, very very weak for most practical cases, so the average engineer would say "no current at all, man", and he'd be right.
There also is some current that would flow from your finger to ground through your feet, but again this current would be negligible since battery voltages usually are low and the human body resistance is high enough to keep this current low (and safe). I'd say that 50V is the turning point: if you touch a wire above that you might be electrocuted and possibly suffer some injuries.
If I understand correctly the question is: "since electric lines are not connected to ground, i.e. current flows from the generator to the load through the hot wire, and back through the neutral wire, why should I be shocked touching only one wire?"
That's because ground is also part of the circuit, and also if it wasn't it becomes part of the circuit when you touch the hot wire with your hand, and the ground with your feet. The neutral wire is connected to ground in the transformer cabinets for safety reasons, so that touching the neutral should not be harmful and wire insulation may be properly sized. Think of a floating line, with neutral at some kV above ground and hot some 230V (110V) above neutral. That would be very, very bad. When you touch the hot wire it's just like you are touching also the neutral, thus you get electrocuted.
I'd add a few lines about that "I thought electricity travels only through path with less resistance". This is false. Given a fixed amount of current, most of it will travel through the path with less resistance, but some of it will travel where resistance is higher. Think of resistance as the width of a road: the wider the road (less resistance) the higher the number of cars that can pass through there. In narrower roads you still find cars, just a smaller amount.
Addendum
About the circuit you sketched: no current is flowing into ground in that case. Ground is only providing a reference and makes sure that a user, that is connected to ground too, won't get electrocuted touching the wire coming out of the '-' terminal of V1. Moreover touching '+' terminal of V1 should get you electrocuted less, since V1+ is only 1V above ground. If you disconnect the ground the '-' can go for example at 1kV, while '+' should be at 1001V. If you touch either wire now you get some serious current through your body.
| improve this answer | |
  • \$\begingroup\$ thx for answer I almost get it but I would like to know is electricity travelling to the ground at the picture and if it is why are they circuits grounded(doesn't it mean electricity is lost?) \$\endgroup\$ – user50533 Aug 1 '14 at 23:46
  • \$\begingroup\$ what do you mean with "at the picture"? Circuits are grounded to avoid their voltages to wander too far from ground potential, preventing users to get electrocuted. No electricity is lost at all. \$\endgroup\$ – Vladimir Cravero Aug 2 '14 at 0:04
  • \$\begingroup\$ Ok now I get it, I didn't see your edit, I'll answer in the answer, check it out in some minutes. \$\endgroup\$ – Vladimir Cravero Aug 2 '14 at 0:04
  • \$\begingroup\$ I can't get why is the current not flowing into ground(ground is connected to the wire) \$\endgroup\$ – user50533 Aug 2 '14 at 0:21
  • \$\begingroup\$ Ground is connected to earth, earth is a big ball, ground is a big ball: why would some current flow into this big ball? Current flows following electric potential variation, and ground is constant. When you first connect ground to your circuit there probably is a brief charge interchange since they are not at the same potential, but that's just a transient and ends very quickly. \$\endgroup\$ – Vladimir Cravero Aug 2 '14 at 7:40
  1. Sure if you grab onto a battery current flows. If you grab onto a DMM you'll find your resistance can go from a few k ohms to M ohms, depending on how hard you grab, and how hard you want to poke yourself. So how much current can vary.
  2. is confused.
