Does BAFO BF-810 USB to Serial Adapter (DB9) support full serial port (hardware flow control) functionality?
If not, how can I test full serial port functionality using serial port only with TX, RX?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityDoes BAFO BF-810 USB to Serial Adapter (DB9) support full serial port (hardware flow control) functionality?
When RS-232 cables were everywhere, a standard piece of test equipment was a small block with D connectors on the ends and LEDs on one face labeled for each significant signal. A quick check shows that such devices are still made, here's a typical example available for about US$11.
I also have a variety of null-modem, gender changers, and 9 pin to 25 pin in my toolbox.
A device like this gives quick confirmation that only the expected pins are driven when attached to each device, and can be left inline to verify that the data and handshake signals are in use.
This does only confirm that the output pins have signal conditioning. It ought to be safe to assume that if TXD
is driven, then RXD
can receive, and similarly for RTS
/CTS
and DSR
/DTR
Likely it has hardware flow control and you can choose to use that function or not.
Since mainstream chip support hardware flow control function, likely, the chip inside this unit has it. Even if the chip has it, depending on manufacturer, it may not be connected to the 9 pin connector, for cost reasons.
However, as modern systems is fast, most can work without hardware flow control.
Try connect rx and tx and see. In rare case of dropping data, select lower speed.
Or you can choose to add hardware flow control wiring and enable the function in software.
