Question
What is the "official" name for this type of connector? (the large black box in the image)
More info...
I need the connection to connect two PCBs together as one was missing from a system that I purchased.
The connection links between the male header pins on two circuit boards and therefore needs to be female-female.
After an extensive search on-line I've come to the conclusion that without knowing what it is called I'm not going to be able to find them.
Diagram of connection
  • 13
    \$\begingroup\$ I've seen them called "gender-bender" but I'm not going to recommend that as a search term! \$\endgroup\$
    – user16324
    Commented Aug 5, 2014 at 12:45
  • \$\begingroup\$ Gender-benders, turn-arounds, <insert connector> female-to-female, and plenty of other terms not suitable for polite company... \$\endgroup\$
    – Matt Young
    Commented Aug 5, 2014 at 12:54
    \$\begingroup\$ When doing this, take care to make sure your connector pin-outs do not become mirror-imaged. You could consider fabricating your own with IDC ribbon-cable connectors. \$\endgroup\$
    – Tut
    Commented Aug 5, 2014 at 12:57
  • \$\begingroup\$ I'm not sure I've ever seen these so they might not be all that common and I couldn't see anything similar at a few suppliers. If you can't locate them raised female PCB mount connectors of varying heights are common and you could solder a couple back-to-back and use epoxy to firmly secure them. \$\endgroup\$
    – PeterJ
    Commented Aug 5, 2014 at 13:26
  • \$\begingroup\$ @PeterJ These types of connectors are most common in A/V and event production where multiple systems need to be integrated together, generally in somewhat creative ways. \$\endgroup\$
    – Matt Young
    Commented Aug 5, 2014 at 14:32
They are officially called Gender Changers but they are commonly referred to as GenderBenders (which may or may not be PC these days...)
  • \$\begingroup\$ I haven't been able to find female-female ones yet (only male-male :( ) but everyone seems to be in agreement that this is the right terminology so thanks anyway! \$\endgroup\$
    – Steven
    Commented Aug 7, 2014 at 7:54
