How can I calculate the transfer function of this bandpass filter characteristic with Butterworth approximation?
  • \$A_{max}\$ = 0,9 dB
  • \$A_{min}\$ = 6,5 dB
  • \$\omega\$3 = 100
  • \$\omega\$1 = 300
  • \$\omega\$2 = 1100
  • \$\omega\$4 = 3300
Which steps do I have to take and what are some good resources for learning these kinds of filter design problems?
Volki, be aware that the design will be rather involved. Here is a short summary of the main steps (active filter design):
  1. Based on the given values (center frequency, bandwidth, midband gain, attenuation values) you must use existing formulas for the bandpass-lowpass transformation. As a result, you have corresponding lowpass requirements and you can calculate the corresponding lowpass order (n=2,3,..).
  2. Applying again corresponding equations you can transform the lowpss poles back to the bandpass poles.
  3. Now you have two alternatives for pole allocation (depending on the required filter order):
    • Series connection of active lowpass and highpass sections
    • Active bandpass stage (or series connection of several stages).
For passive topologies, you must rely on filter catalogues. In any case - I strongly recommend to make use from filter design programs which are available. For example:
Passive: AADE;
Active: Filter Free, FilterLab, FilterPro
  • \$\begingroup\$ A first look on the given data has shown that a second-order bandpass can meet the requirements. \$\endgroup\$ – LvW Aug 8 '14 at 15:17
