Would you give me a hand ?
I have an IR sensor with 3 pins. It looks like the one in the picture, and I did not find any datasheet for it on the internet. actually, I have 3 questions :
1- I want to identify its pins ? (Where can I put the positive, ground ...etc. ?)
2- How to connect it with a visible LED so that when the IR sensor receive IR Rays, the LED lights up ?
3- Should I transmit IR Rays with a specific frequency ? or just connect IR LED to the power only ?
  • \$\begingroup\$ Helping you is quite difficult. Where did you buy/found this receiver? Can you provide a photo of it? \$\endgroup\$ – Vladimir Cravero Aug 9 '14 at 10:42
  • \$\begingroup\$ Hi Vladimir, I found it in an receiver (TV). this is the picture : i.stack.imgur.com/H91t9.jpg \$\endgroup\$ – Michael George Aug 9 '14 at 10:44
  • \$\begingroup\$ A photo of the pcb where you took it from is the only way to be extra sure of the pinout. These guys have two power pins (Vcc and ground) and a digital output. They expect a IR signal pulsed at some 10s of kHz modulated by your information signal. \$\endgroup\$ – Vladimir Cravero Aug 9 '14 at 10:46
  • \$\begingroup\$ thank you very much for your answer :) is there any way to identify the Vcc and ground ? \$\endgroup\$ – Michael George Aug 9 '14 at 10:49
    \$\begingroup\$ Read the datasheet. \$\endgroup\$ – Phil Frost Aug 9 '14 at 12:27
I have an IR receiver that looks like yours. The one I have is equivalent to this TSOP38238 from Adafruit:: enter image description here
This IR detector demodulates a modulated IR at 38kHz and provides a digital decoded signal at the output.
Assuming it's the same one; here's the pinout: enter image description here
The DATASHEET is available here (TSOP38238).
Head over to Adafruit for all the details including how to connect to a visible LED: enter image description here
I have a method to find the pin outs ,my method is by luck though but is quite easy if you got the sensor out of a PCB of an old electronic if its able to power up. if can power it up do a continuity test find in the 3 pins which is ground after you found the ground mark it if your able to or remember it and find another pin with a voltage of 3.3 volts and that it u found the pin out hope i help someone
It looks very much like a TSOP382xx from Vishay, available at Adafruit: https://www.sparkfun.com/products/10266 You can find a datasheet there also.
The carrier frequency depends on which model you have, the last two digits in the part number.
As you can see from the block diagram above pin 1 is your output (far left on your picture). The receiver sinks pin 1 when the correct carrier is detected. But it can only sink a maximum of 5mA so you must limit the diode current if you hook one up directly to the output. I would use a buffer stage of some sorts. Hint: you could probably make one yourself with a PNP transistor.
