EDIT: What is the maximum resistance that can be put in series with an input to the PIC.
Original Question: I am designing a clamping circuit to protect my microcontroller's pins, I need to know the minimum current required by my microcontroller to register input so that I can bias my external clamping diodes properly, without risking normal operation of my microcontroller.
Edit: Microcontroller is to read digital inputs in an EMI and ESD prone environment and I want to clamp both negative and positive voltages in the range of about -0.3V to (VDD + 0.3V), this range is provided in the datasheet under Electrical Characteristics.
I am using this PIC24, I think this has something to do with leakage current but I am not sure.
