Let me establish some facts I have understood by myself: The polarity of resistor does not change, as the current from A.C source flowing through does not change direction. The D.C potential difference value fluctuates from zero to maximum. To reduce this fluctuation a smoothing capacitor is used.
What I don't understand is:
- Is the equation \$t=RC\$ applicable to both charging and discharging of capacitor?
- Is the time constant the same in both cases?
- If so then why does the capacitor charge fully in time \$t\$ as the potential difference rises to maximum initially but discharge slowly as the potential difference falls? Its time constant for charging and discharging is different apparently! It's greater for discharging and less for charging. Why is this?
- Initially, as the capacitor charges won't it cause some of the current to be diverted towards itself and less current would flow through resistor, as they are arranged in parallel?
t = RC
formula establishes a time constant. When the voltage on the RC network suddenly changes (is subject to a "step function"), the time constant tells us how much time is required to reach 63% of the way between the old voltage and the new voltage. This applies in other kinds of physical systems. \$\endgroup\$
