6
I'm needing to create a 4 bit, 16 input multiplexer. I know I could describe this as a long list of S => when "0000" etc.. but I think that's not very clean, and I'd like to opt for a generic n-bit multiplexer so I can reuse it later for more inputs or whatever.
How would you do this?
It's like this:
use ieee.numeric_std.all;
signal din :std_logic_vector (15 downto 0);  -- must be "downto 0"
signal sel :std_logic_vector (3 downto 0);
dout <= din(conv_integer(sel));
Hope that helps!
Addition: If you'd need a multiple bit wide mux then...
type data_bus_array is array(7 downto 0) of std_logic_vector (31 downto 0);
signal din :data_bus_array;
signal dout :std_logic_vector (31 downto 0);
This is where VHDL gets a little bit wordy, since sometimes it's not "compact" to fill in that data bus array just to do a simple mux. But, there you have it...
  • \$\begingroup\$ Wow. Now that's just too easy. what if you wanted multiple bit inputs though? \$\endgroup\$ – Earlz Apr 3 '11 at 21:56
  • \$\begingroup\$ @Earlz I added multi-bit-wide stuff to my answer, above. \$\endgroup\$ – user3624 Apr 3 '11 at 23:09
    \$\begingroup\$ Nice. Would've been a bit better if you had added generics in, but that's pretty easy to change around \$\endgroup\$ – Earlz Apr 4 '11 at 3:22
  • \$\begingroup\$ You have numeric_std - yay! But then you need "to_integer", not "conv_integer". Then, why not make sel an "unsigned" type? \$\endgroup\$ – Martin Thompson Apr 4 '11 at 12:30
