I've noticed that if I build a Colpitts oscillator (audio range) using a transistor in the common base configuration (similar to the circuit here) I can vary the voltage on the base and get a wide range of frequencies. This is a very simple circuit, so what's wrong with it? All of the VCO schematics I see are substantially more complicated. I can think of several potential reasons for this. Can you identify which are the case and elaborate on why VCO designs are often so complex?
  • In an RF design, this might suffer from a small bandwidth - perhaps the frequency can't be modulated enough to be useful
  • Perhaps the frequency stability is poor, or the phase noise is bad
  • The frequency vs voltage could be highly nonlinear (although it seemed fairly linear to my ear - I do not have fancy instruments to measure these things)
  • It could be temperature dependent
  • The amplitude could change too much with changing base voltage
  • Some other reason?
  • \$\begingroup\$ The circuit you linked to is for 50 MHz and not "audio range" \$\endgroup\$
    Commented Aug 14, 2014 at 8:42
  • \$\begingroup\$ Yes I put in a much larger inductor and much larger capacitors, tweaked the resistors, and used a different supply voltage, but it's still basically the same circuit. \$\endgroup\$
    – Void Star
    Commented Aug 15, 2014 at 0:44
  • \$\begingroup\$ It's not really the same circuit regards parasitic components any more. \$\endgroup\$
    Commented Aug 15, 2014 at 8:20
"Can you identify which are the case and elaborate on why VCO designs are often so complex?"
Each oscillator has to fulfill Barkhausen´s oscillation condition (Loop gain slightly larger than unity for start-up and equal to unity for continuous oscillation). This condition must be met for one single frequency only!. For most of the oscillator topologies a change of frequency (tuning of the frequency dependent part) is connected with a change in amplitude - and, thus, alters the oscillation condition.
There are only a few simple oscillator circuits that allow frequency tuning (over a relatively broad frequency band) without disturbing the oscillation condition. Normally, as much as at least two active elements are required in those cases. However, fine tuning often is possible with basic oscillator structures because corresponding (small) gain changes can be compensated by the non-linear amplitude stabilization (if existing!).
EDIT: Some authors are using the term "orthogonal" to indicate that the described oscillator features independent control of the frequency and the oscillation condition.
