I am currently trying to use a 5 Pin relay on a Motorcycle indicator circuit. The concept is I have a Daytime Running Light (DRL) that is in the same housing as the indicator. When the indicator is on, I would like the DRL to go off.
So far, I have wired a 5 Pin Relay with a Capacitor as the current from the indicator is not constant (As the indicators have to flash). Initially I tried building this circuit without a Resistor. However, either my capacitors are not big enough (Tried 1000uf & 4700uf) or they are discharging too quickly without the resistor.
Relay is 20/10amp 12v with a current draw of 0.15amp.
How do I work out what size resistor I need?
The current circuit is like this
Indicator Wire --> 1w Diode --> 16v Capacitor (1000uf or 4700uf) --> 5 Pin Relay
I need the capacitor to output enough current to keep the relay open (NC Relay) for approximately 1/2 second (between the flashes of the indicator).
