I'm using the RDM6300 125kHz reader module in combination with Arduino Uno to read my tags.
The tags themselves have their ID as a label. When I then try to read the cards, I receive another ID as the indicated label. For example:
Tag label: 0009471985
Reader Output: 0x85009087F163 = 146237471322467
But when I ignore the first and last byte, the ID is correct:
Ignoring first and last byte: 0x009087F1 = 9471985
This happens with all my tags I read. But the bytes change for every tag, so they can't symbolize the beginning and ending of the transmission. When I use an other Chinese reader, it outputs me the correct ID as decimal numbers. Should I now ignore those two bytes, when creating access control and focus on the ID indicated on the tag? And what do those bytes represent? Are they a checksum?
Thank you!
Yes, it's safe to ignore those bytes, unless you plan on using them. They are the header and footer respectively. The checksum is in the first two bytes.
| improve this answer | |
