In this circuit LM358N 1MHz 32V dual op amp is used (+12V and -12V). The question is, can I simply replace it with NE5532N 10MHz +-22V dual op amp for up to 8MHz DDS signal source?
Basically, this circuit has DDS output generated via R2R resistor network and adjusted via LM358N offset and amplitude regulating circuits. Offset can be regulated in range +5V..-5V while amplitude in range 0..10V.
