I've been trying to figure out the inductance in Henries from a schematic of a Rabbit Microprocessor development board, however, instead of finding an inductance value over the components in question, theres an ohm/amp value, I thought maybe it was the inductive reactance, but theres only DC in this circuit and most of the inductors are probably being used as filter elements. However , to add more confusion, in this same schematic, some inductors are stated in Henries while others are stated in Ohms/Amps.
*So how should I interpret an inductor whose value is in ohms, It cant be inductive reactance can it? *
I dont understand how is it related or is it simply a ferrite bead with a certain dc resistance? Here are pictures of the schematic im analyzing:
Here you can see one of the inductors in ohms
This second pic is also from the same schematic, while there is an inductor stated in Henries (nH to be precise) the other inductor is in ohms
