Please help me explain why the efficiency of the wire does not follow a distinct path (ie R^2 value is low).
Graph 1 Efficiency of wire vs current: http://postimg.org/image/p49bzm4ab/
Is is to do with non-linear relationship between resistance and efficiency (see link below)?
Graph 2: Change in temperature vs wire efficiency
http://postimg.org/image/t3oihsb6p/
  • \$\begingroup\$ Please explain "efficiency of the wire". \$\endgroup\$ – Dzarda Aug 21 '14 at 10:13
  • \$\begingroup\$ The power in/ the power out *100% \$\endgroup\$ – Ashmar Barbour Aug 21 '14 at 10:19
  • \$\begingroup\$ Given that definition, I'd like to have some of the wire you tested. It is showing 180% efficiency - free power. I would say you've got some kind of error in your measuring or in your math. \$\endgroup\$ – JRE Aug 21 '14 at 10:24
  • \$\begingroup\$ How are you measuring power in and power out? Can you draw a schematic, or post a photo of the schematic? \$\endgroup\$ – gbulmer Aug 21 '14 at 10:42
  • \$\begingroup\$ I am measuring the power left after passing through the wire. The maximum efficiency is not 180% but the axes do extend to past 100% as it has two y axis. Here is a table of data found : postimg.org/image/70do12cst \$\endgroup\$ – Ashmar Barbour Aug 21 '14 at 10:54
