I am using PIC18f microcontroller. I have to write a 16 bit integer variables (2 bytes) which was cast into two character variable i.e to write each byte in a consecutive adrressess of EEPROM. By first I have to write a upper byte(8bit data) in the EEPROM. I am unable to get the higher 8 bit of the integer variable by the following code (where I am able to write the lower eight bit of the integer variable ). My code is
void int_EEPROM_putc(unsigned char address, unsigned char data);
unsigned char int_EEPROM_getc(unsigned char address);
unsigned char c;
unsigned int d;
unsigned char* e;
unsigned char f;
void main()
d=0xffff;
e=(unsigned char*)&d;
//f=*e
f=*(e+1);
int_EEPROM_putc(0x02,f);
delay_ms(100);
c=int_EEPROM_getc(0x02);
while(true)
if(c==255)
PORTB=~PORTB;
else
PORTB=0xff;
c
to be 0xFF, but it isn't? \$\endgroup\$ – Rev1.0 Aug 21 '14 at 11:490xFF
, I would use some initial value liked=0xAABB;
to differentiate the values. \$\endgroup\$ – Rev1.0 Aug 21 '14 at 11:52
