I am trying to control a LED using a high-power 433MHz transmitter receiver pair, with transmitter connected to my Arduino Nano.
Here is the transmitter (XLPCF20): http://www.colorapples.com/rf-wireless-transmitter-module-315-or-43392mhz-xlpcf20-p-38493.html
Here is the receiver (CDR 5 B): http://www.amazon.co.uk/433MHZ-115dbm-Wireless-Receiver-CDR-5-B/dp/B00COD96UG
I can send HIGH to a data channel at the transmitter (it has 4 channels) and receive the HIGH input at the same channel at the receiver, successfully lighting up a LED. This is my current test sketch:
void setup(){
pinMode(8, OUTPUT);
void loop(){
digitalWrite(8, HIGH);
delay(122); //this is the important line
digitalWrite(8, LOW);
delay(100);
This works well, however, if I change the 122ms delay at the falling edge to 121ms (or anything below that) I have no output at the receiver. The LED doesn't light at all. It's the same for all channels, there's a sharp change at that very border between 121ms and 122ms (found the exact value by trial and error). At the transmitter/Arduino, the output signal is clear so it's an error with the transmitter or receiver. I've used other, much simpler/cheaper 433MHz transmitter/receiver pairs in the past with no such issue. At the rising edge (second delay call, the one with 100ms), there's another issue when I drop below 13ms. At exactly 12ms, the LED is unstable, it sometimes blinks as expected, but sometimes just lights up. Anything below 12ms, the LED is constantly high, not a single blink.
UPDATE: If I use _delay_ms
instead of regular delay
, I get about 1ms
more room for both edges, but below that, it's still the same.
UPDATE 2: I've tried changing to different output pins on my Nano, both PWM and non-PWM ones. Nothing changes.
What would be the problem?
_delay_ms()
instead? \$\endgroup\$
