I have this sample program to blink LED with PIC18F4550 using external oscillator.
I'm using a 20.000 MHz crystal oscillator with 30pF capacitors.
The problem is when I wire the capacitors the the ground the LED doesn't blink (still off), but when I disconnect them from ground (not wired) the LED starts blinking. Blink speed change with _XTAL_FREQ
Program works well with internal oscillator (just by setting FOSC = INTOSCIO_EC
Is there direction wiring of capacitor or oscillator?
Ground here is PIC Vss
This is when using PICKIT2 directly. When using the circuit alone like the scheme, nothing happens with FOSC = INTOSCIO_EC
configuration (not working), but works well with internal oscillator.
#include<p18f4550.h>
#include "delays.h"
/* COMPILER DIRECTIVES FOR CHIP CONFIGURATION BITS*/
#pragma config FOSC = HS //INTOSCIO_EC /* Sets the oscillator mode to HS */
#pragma config WDT = OFF /* Turns the watchdog timer off */
#pragma config LVP = OFF /* Turns low voltage programming off */
#pragma config DEBUG = OFF /* Compiles without extra debug code */
#define _XTAL_FREQ 12000000 //delay_ms change by changing this
void main(void) {
TRISD = 0xF0; // PORT B Setting: Set all the pins in port B to Output.
while (1) {
LATDbits.LATD0 = 1; // RD-0 to High
LATDbits.LATD1 = 1; // RD-1 to High
__delay_ms(50); // Half sec delay
LATDbits.LATD0 = 0; // RD-0 to LOW
LATDbits.LATD1 = 0; // RD-1 to LOW
/* THE END */
