I have a problem with the asynchronous input signal synchronization. I am trying to make the IIC_Slave based on Cyclone III FPGA Starter Kit.
I saw 3 cases:
If I do not use synchronization triggers, I can enjoy a metastable clock control that affects as a number of positive- and negative- edges in each clock front. It is shown at pic 1.
If I use the synchronization triggers, this number of fronts disappears (as expected) but a new bug is appeared (it look’s like a reset signal on some negative edges of the clock signal). At the same time the reset signal are not detected by oscilloscope.
If I use the case 2 conditions with the SignalTap generated module all works correct! But it is not a valid possibility to solve problems. (738 logic elements and 41000 memory bits are wasted)
Here are explanations for the oscillograms. The digital signal D7 – reset for the counter. The digital signals D6-D1 – bits of the shift counter. The yellow analog signal – data line from IIC. The green analog signal – clock line from IIC.
Please tell me if you have any idea about this situation. I am trying to make it works about a week and have a strong headache. I can’t even formulate a appropriate question for google.
