I'm a Microchip guy, but I'm helping a customer out with an Atmel project using the ATmega88PA project they inherited from another division. I'm using AVR Studio 5 and I would like to compile the fuse selections into the source code and eventually hex file. How do I do this?
You can't, they have to be set in AVR Studio.
If you use the AVRdude utility, programming and fuse settings can be automated with makefiles.
  • \$\begingroup\$ So, how do you setup production for these chips? Is there another fuse setup file I have to generate? \$\endgroup\$
    – kenny
    Commented Apr 6, 2011 at 18:32
    \$\begingroup\$ Either save the fuse options as command line values or in a file as is described here: electrons.psychogenic.com/modules/arms/art/14/… and also fuse calculator here: engbedded.com/fusecalc \$\endgroup\$
    – AngryEE
    Commented Apr 7, 2011 at 0:08
  • \$\begingroup\$ @kenny That is a good question (maybe you should ask it). We use a command line programmer and call it with the correct fuse bit settings from scripts (each product gets a new script) but we are a rather small shop. What do the big guys use for AVRs? \$\endgroup\$
    – jpc
    Commented Apr 7, 2011 at 0:18
  • \$\begingroup\$ @AngryEE and @jpc, thanks. I didn't realize those command line tools existed. And I see that AVRDude is a console application now. \$\endgroup\$
    – kenny
    Commented Apr 7, 2011 at 10:53
    \$\begingroup\$ Gang programmer, ha! He'll set a fuse in yo chip. \$\endgroup\$
    – AngryEE
    Commented Apr 7, 2011 at 12:05
