I'd like to use a Tripp Lite PR40 as a backup 12V UPS by connecting it to a battery before a couple motors in parallel. The battery is 125AH deep cycle AGM. Can I do this?
The manual says that the power supply can be used to charge a battery but that a 40A fuse should be in between to keep it from back feeding and frying the power supply. I think I can do this with a diode but I'm not aware of any 12V 40 amp diodes. Any input on the type of diode and do I need a circuit board of some sort to wire it in?
If not, are there smaller diodes like 20A I could use?
closed as off-topic by Olin Lathrop, Leon Heller, Chetan Bhargava, Daniel Grillo, Matt Young Aug 29 '14 at 13:14
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Olin Lathrop, Leon Heller, Chetan Bhargava, Daniel Grillo, Matt Young
If this question can be reworded to fit the rules in the help center, please edit the question.
You would only have backfeed current if the battery was at a higher voltage than the power supply leads. This is highly improbably has most batteries will not hold a charge higher than they are spec'd.
Personally I have a deep cycle SGM battery in parallel with a 12V PSU (floats at 13.8). and I have never had any problems.
The only major concern that I know of is overheating of the battery, causing it to vent noxious fumes, but as long as you arent shorting the battery or drawing insane amounts of current you should be fine. I still wouldn't recommend a homebrew solution like this for anywhere in your home, its an ok garage UPS though.
However if you want to use this anywhere where people live, I would definitely put some sort of diode in, http://www.digikey.com/product-detail/en/APT75DQ120BG/APT75DQ120BG-ND/1494832 would be sufficient, it can handle the voltage drop from 13.8 to 12. It has at least a 10* reverse stand off (this is my ultra safe rule of thumb). and it can handle double your amperage load.
Purely because this is dangerous I would officially recommend buying a professional UPC.
