I am learning interfacing of Atmega 16a with 16X2 LCD. I have a written a header file for routines which will used frequently and every time I want to interface with LCD using Atmega 16a I use this header file.
here is my LCD header file:
#include<stdlib.h>
#include<avr/io.h>
#include<util/delay.h>
int cx=1;
int cy=1;
void LCD_Send(unsigned char c,unsigned char DC)
if(DC==0)
PORTC=0x0F & (c>>4);
PORTC=PORTC|(1<<5);
_delay_ms(1);
PORTC=PORTC & (~(1<<5));
_delay_ms(1);
PORTC=0x0F & (c);
PORTC=PORTC | (1<<5);
_delay_ms(1);
_delay_ms(1);
else if(DC==1)
PORTC=PORTC | (1<<7);
PORTC=PORTC|(1<<5);
_delay_ms(1);
_delay_ms(1);
PORTC=0x0F & (c);
_delay_ms(1);
_delay_ms(1);
return ;
void LCD_init(void)
DDRC=0b11101111;
LCD_Send(0x01,0);
LCD_Send(0x0F,0);
LCD_Send(0x28,0);
cx=1;cy=1;
return ;
void LCD_Send_String(char* s)
for(int i=0;s[i]!='\0';i++)
LCD_Send(s[i],1);
if(cx==16)
cx=1;cy++;
LCD_Send(0xC0,0);
else
cx++;
return ;
void LCD_GotoXY(unsigned int x,unsigned int y)
if(y==1)
char addr=0x80;
addr=addr+(x-1);
LCD_Send(addr,0);
else if(y==2)
char addr=0xC0;
addr=addr+(x-1);
LCD_Send(addr,0);
cx=x; cy=y;
return ;
void LCD_Print(int data,unsigned int x,unsigned int y)
char string[10];
LCD_GotoXY(x,y);
itoa(data,string,10);
LCD_Send_String(string);
return ;
Here RS,R/W and E are PC7,PC6 and PC5 respectively, DB4,DB5,DB6,DB7 are PC0,PC1,PC2,PC3 respectively. I am using 4 bit mode for input.
here is my main.c file (the code which will be run on the microprocessor):
#include"lcd.h"
int main(void)
LCD_init();
char s[20]="1234567890123456789";
LCD_Send_String(s);
return 0;
When I flash the memory with the HEX file then reset the LCD is displaying fine
Then when I reset later it displays random variables(infact I can see that the second line doesnt change at all, it means that the screen is not cleared but a command was written to LCD_init()
to clear screen)
I am pretty sure that nothing is wrong with board and the connections because it works with other header files, I am pretty sure that it is a fault in my code. I would really thankful if anyone help me fixing this code If i reset again it displays the correct sequence as in first image
