From my understanding, the Bluetooth signal is using a 2.4 GHz frequency.
However, when someone is playing with a 40 MHz RC vehicle, the Bluetooth signal keep on getting interrupted or disconnected.
Does the 40 MHz RC vehicle is the root cause that cause the Bluetooth to get interrupt or disconnect?
If it is not the RC vehicle, what might likely cause such interference to the Bluetooth signal?
Thank you.
