I'm trying to understand how to connect a SPI device (a mifare RC522 RFID board) over long distance to my RPi via SPI.
I searched and find I could connect those via SPI over RS485 using a MAX490. (http://forum.arduino.cc/index.php/topic,93234.0.html)
Could anyone explain, maybe with a schematic, how to connect those devices? And do I need some software changes?
    \$\begingroup\$ It's good that you've done preliminary research. But, if you found that you can connect "SPI over RS485 using a max485", then please post a link to where you've found that. \$\endgroup\$ Sep 3, 2014 at 16:57
  • \$\begingroup\$ Sorry, I meant MAX490: forum.arduino.cc/index.php/topic,93234.0.html \$\endgroup\$
    – bitbang
    Sep 3, 2014 at 18:07
  • \$\begingroup\$ The MAX490 is not stateful, you would just be using it to drive/receive balanced signals and would need several to cover all of the SPI signals. You might also consider using asynchronous serial over RS485 to talk to a small microcontroller (/barebone `duino) and have that talk to the board via SPI. It's also entirely possible that with sound electrical design and slow clock rates, your SPI device would simply work at your distance. How long is "long"? \$\endgroup\$ Sep 3, 2014 at 20:34
  • \$\begingroup\$ About 10 meters \$\endgroup\$
    – bitbang
    Sep 3, 2014 at 21:30
    \$\begingroup\$ What is the SPI clock - if you are trying to read remote devices then you might have a problem due to the data received being delayed too much. \$\endgroup\$
    Sep 3, 2014 at 22:13
The single-ended SPI signals can be converted to differential pairs, which are more robust in presence of EMI and can go the distance. Then the differential pairs can be converted back to single-ended SPI signals, and connected directly to peripherals (ADC, I/O expanders, and such). That's what the original forum post is proposing.
MAX490 has 2 different sub-circuits.
One sub-circuits is a differential bus transmitter. It can convert a normal single-ended SPI signal to a differential signal.
The other sub-circuit is a differential bus receiver. It can convert a differential signal back to single-ended.
enter image description here (fig. 2 in the datasheet)
In order to connect the SPI bus this way, 3x MAX490 would be required on each side. Something like this.
Clock delay
The above approach has a clock delay problem. So it has limitation in bus length and bit rate. This is what @Andy was referring to in his comment.
Here's an application note that further explores clock delay and proposed a solution (and this one too). However, that solution requires 2 separate SPI peripherals on the microcontroller.
Here's another app note on clock delay in the context of high speed SPI.
