Looking at the datasheets, I'm not sure their specifics match;
TIP127 and ULN2003A
My intention is to do something like this, but with the ULN2003A, that I have already:
wirings
The reason why is that I want to remove the provided driver/power supply (5V 12V, driving 6 LEDs 0,25W each) and use PWM with the RPi to dim the strip's leds (using an external 5V power supply). I've already done this to regulate a 12V fan (but I understand this is another story).
    \$\begingroup\$ How much current does that RGB thingy draw? (And connecting TIP120's without base resistors is not a good idea.) \$\endgroup\$ Commented Sep 4, 2014 at 16:53
  • \$\begingroup\$ Your question title and graphic references TIP120's, but the datasheet link you provided references TIP127's. I'm assuming TIP120 is correct because that's a NPN transistor. The TIP127 is a PNP, which will definitely NOT work in this circuit. \$\endgroup\$
    – Dan Laks
    Commented Sep 4, 2014 at 17:08
  • \$\begingroup\$ @WoutervanOoijen I'm not sure how much current my strip drowns. It's a 6 x 0,25W LED strip (1,5W tot.) using 5V. Amperage should be written on the power supply but I don't have them now. \$\endgroup\$
    – dentex
    Commented Sep 4, 2014 at 17:18
  • \$\begingroup\$ @DanLaks The pdf contains data also for the TIP120. \$\endgroup\$
    – dentex
    Commented Sep 4, 2014 at 17:19
For the most part, yes, the ULN2003A will work in this circuit, but with some caveats.
The VCE(sat) is slightly higher for the ULN2003A vs the TIP120, which means the LEDs will have slightly less voltage across them (and so slightly dimmer). But that may not matter for your application.
My biggest concern is the total current through the ULN2003A chip when all three LEDs are on. Figure 14 of the datasheet shows the maximum current you can drive through each of the Darlington pairs. As you can see, if you have all three LEDs on at 100% duty cycle, each color can only draw a little more than 150mA. That's 450mA total. Any more than that and the chip will overheat. It's important to get a handle on how much current your LED strip pulls. enter image description here
If, as you said in your comment, the strip is 1.5W with a 12V power supply, then presumably that translates to 125mA total. If that's true, you're probably ok then.
EDIT: You indicated you're using a 5V power supply. Since your LED strip is sized for 12V, the LEDs may not even light up. Especially the blue LED. If they do light up, they'll be significantly dimmer than they were designed to be.
  • \$\begingroup\$ See the edit to my answer about the use of a 5V power supply on this circuit. \$\endgroup\$
    – Dan Laks
    Commented Sep 4, 2014 at 17:39
  • \$\begingroup\$ So is the LED strip a 12V strip or a 5V strip? Is the image you used in your picture a photograph of the actual strip or something you grabbed off the internet? \$\endgroup\$
    – Dan Laks
    Commented Sep 4, 2014 at 18:01
  • \$\begingroup\$ Ok. I checked. The strip's power supply is rated 12V at 350mA. Sorry for the mess ;) \$\endgroup\$
    – dentex
    Commented Sep 5, 2014 at 6:40
  • \$\begingroup\$ Accepting the answer, you were right. Although the power supply it's 350mA, the measured current across the strip it's about 100mA. Thanks. \$\endgroup\$
    – dentex
    Commented Sep 7, 2014 at 6:16
VI(on) (VCE=2V, IC=300mA): 3V
Achievable by a 3.3V CMOS output. Lower currents have a lower VI, which would be a good thing.
VCE(sat) Max (IC=350mA): 1.6V
Your strip would need to be okay with 10.4V. Lower currents have a lower voltage drop (also good).
The common won't interfere, and actually won't matter since you're not driving an inductive load.
So once you know what current and voltage each component requires, you can decide if it will work for you.
  • \$\begingroup\$ Thanks for the answer, but due to my level of skill in this field, I don't understand it. I can tell that my strip uses a small driver/power supply of 5V and it's composed of 6 LEDS 0,25W each. I'm going to edit the Q to explain better what I want to do with it. Thanks again for your help. \$\endgroup\$
    – dentex
    Commented Sep 4, 2014 at 17:22
  • \$\begingroup\$ I think that in the future you need to qualify "like this", since what you've described is not like that in very many ways. \$\endgroup\$ Commented Sep 4, 2014 at 17:24
  • \$\begingroup\$ Do you mean qualify myself as a beginner? Sure, it seems appropriate. \$\endgroup\$
    – dentex
    Commented Sep 4, 2014 at 17:28
  • \$\begingroup\$ Qualify that the issue isn't really "like this", since the components are very different. \$\endgroup\$ Commented Sep 4, 2014 at 17:32
