How can I connecting two different DC power sources together? for example 15Vdc(5Amp) with 5Vdc(2Amp). I want to make one DC source (20Vdc,7Amp) by more powerful supplies.
    \$\begingroup\$ It cannot be done. \$\endgroup\$ – Andy aka Sep 5 '14 at 13:00
    \$\begingroup\$ What's with the close votes? Yes this question is at a low level, but that isn't a close reason. It's clear enough what is being asked, and power supplies are certainly on topic. \$\endgroup\$ – Olin Lathrop Sep 5 '14 at 14:22
13
You can connect them in series to add the voltages, but the resulting current capability will be the lower of the two current ratings. Think of it like tying a 5 foot and 15 foot rope together. You get a 20 foot rope, but its strength is whatever the strength of the weaker rope is.
No, you can't put two supplies together in any way to add both their current rating and their voltage. This should be clear just from the power output alone. The 15 V 5 A supply can deliver 75 W. The 5 V 2 A supply can deliver 10 W. Both together therefore can't deliver more than 85 W. However, 20 V at 7 A would be 140 W. That's a free lunch physics won't let you have.
  • \$\begingroup\$ Man, you really know your stuff! \$\endgroup\$ – user148298 Jun 12 '17 at 12:54
If you want 20VDC from a 15VDC supply and a 5VDC supply, you would connect them in series. However, you must make sure that they are floating with respect to ground. If both supplies are grounded, then you cannot connect them in series. Also, note that the maximum current that can be drawn from the series connected supplies is equal to the lower of the current ratings of the 2 supplies. In your case, connecting a 2 amp supply and a 5 amp supply in series results in a supply that has a maximum rating of 2 amp.
Power = volts x amps. So you want to get (20*7) 140W out of (15*5) = 75W + (2*10) = 10W. 75+10 is less than 140, so it cannot be done.
How to connect supplies together is complicated and depends on the type of supply, so don't just connect supplies together without finding more. You make more volts by connecting in series, and you make more amps by connecting in parallel, you can't have more of both!
In present case, you can't obtain the desired output. There are three types of battery (DC Source) connections you should remember.
  1. Series
  2. Parallel
  3. Series - Parallel
Series connection Such connection is used for adding voltages. In your present case 15 V + 5 V = 20. But remember current always remains same in series. If you'll connect two indifferent sources (in terms of current) in series. It'll damage. Figure below displays series connection:
Series connection of battery
Parallel connection Such connection is used for adding amps. In your case 2 Amp + 7 Amp = 9 Amps, but remember voltage sources with different values should never be added in parallel. In case of same values voltage, you can do so. See figure below: Parallel connection of battery
Series-Parallel Connection Such connection is used for adding amps, as well as volts but remember the rules. Both of above are applicable here. Series-Parallel connection of batteries
Hopefully, the info above is quite enough and it helps you. For more details check this link on 3 different types of battery connections with mathematical calculations.
You can connect the +ve of one supply to the -ve of another supply to get 20V, but you will be limited to the smallest supplies current (2 amps in this case).
  • \$\begingroup\$ The extra bit of Barry's answer is very important. If the negative of both is referenced to the same place (earth?) then you've just shorted one out. \$\endgroup\$ – Colin Mar 7 '17 at 12:25
protected by Community May 30 '18 at 22:50
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
